slave cylinder not coming off
Codyvieth
65
3
Aug 9, 2014
madison, Wisconsin
i unbolted the 2 bolts for the slave cylinder and took off the line but the slave cylinder hasnt even moved its just stuck there. I tried to pry it with a screw driver and hitting it with a hammer but it hasn't even moved.
pretty sure the wrong bolts are taken out bud. If you're positive its right, try depressing your clutch pedal a bit. the force would separate it no problem.
he already disconnected the line.
why did you disconnect it? to replace or what?
if its to replace the slave, smack or pry it harder to get it off. other than that, if you cant get it off of there, go to the gym. LOL.
Post a pic of the slave. Was it installed with loctite? There's no reason it shouldn't just fall off without the two bolts...
Did you ever get the slave off? What was the issue?
sounds like the wrong bolt may have been removed. should be 2 12 m bolts which go in from opposite directions. 1 from engine side other from trans side.
