Brownrice80
- 48
- 1
- Aug 6, 2014
Menifee,
California
So I will despair from explaining my WHOLE background and save it for my intro post. For the time being, I am hoping that I can get some help/advice that I'm having with my recent purchase. So I took a gamble and purchased a non running 1994 Eclipse GSX . We started with the fuel pump as we didn't hear and later confirmed by removing the return hose that it was not working. We threw in a walbro and did the fuel pump relay mod while we were at it. It was at that time that we noticed the black/white wire that should be showing power did not. We used the yellow/blue wire instead as trigger (I understand it is the low fuel light) and it did the job for now. So after that the GSX started and idled. . .SUCCESS! I had the check engine light on but the diagnostic plug was not working and not respond to my attempt at pulling it's code. That led me to find a dead alarm system tucked under the dash. I removed and repaired the wires they damaged and also noticed the alarm had cut the black/white wire as a fuel pump kill i presume. After those repairs i checked my diagnostic plug and now was working! I also checked the black/white wire in at the fuel pump and also see power upon engine crank and running. Ok, so we are slowly getting somewhere right?
I use a buzzer to retrieve the CEL codes. I get:
13 - Intake Air Temperature Sensor
14 - Throttle Position Sensor
21 - Engine Coolant Temperature Sensor
25 - Barometric Pressure Sensor
My first impression was wow, could all these sensors really be bad and need replacing?? I have both the chilton's guide, Hanes Manual, and downloaded FSM (what i could find, we can go into that later! ) by following all the check procedures I determined that all the sensors were fine the IAT, TPS, and BPS all passed the volt meter tests. all OHM readings and resistance values were within specs with the repair books. We did a few maintenance things like drain and refill gas, change plugs, wires, engine oil, etc. I tried resetting the codes and each and every one of them returned within 30sec of starting it up again.
I drove the GSX around the neighborwood and it feels fine. It seems to accelerate fine. Boost shows and I can hear building. Idle's perfectly. rev's smoothly and throughout all rpms. shifts awesome. all despite showing these 4 codes. My research also hints at a possible ECU problem (which i have not checked or opened up yet) but could the ECU be bad and still run so good? could all these sensors be bad and still run so good? I'm kind of at a loss here. Where should I start next? check the ECU? Should I buy the least expensive sensor and replace to see if the CEL disappears? Seek the help of a local 1G DSM'r and try another ECU? I know this is a lot of reading but I'm trying to provide everything I can see relevant and provide as much information about the problem as I can. Thank you all in advance, I really appreciate the help
-Brownrice80
-Brownrice80
