2G What kind of flywheel is this?
tjramsy
3
Jul 12, 2014
Gloucester, Massachusetts
I was told by the person that built my car (who sold it to the man I bought it from) that the car had a lightweight fidanza flywheel. It doesn't look like any of the fidanzas that I have found via searching, so let me know what you think, please.
Hmm, so most likely a cheapo. Well at least I know it's at the correct spec of -.610. Let's hope it holds up. I have a set of arp flywheel bolts to hold it on there and a tube of red loctite as well.
By the way, what's the deal with the arp ultra torque lubricant, do I need to use that at all or should I just put a small dab of the loctite on the holes for the flywheel bolts and that should be fine?
Def not an aluminum fidanza, they have a replaceable steel plate that is attached by like 16+ screws. I have one and I could take a pic of it if need be, but you already know so it's probably worth buying a better one cause of you've ever seen a video of a flywheel busting off and tearing into the dash, you'll wanna play it safe. Even with a scatter shield it can do alot of damage.
