74runner
- 137
- 3
- Nov 21, 2009
Brantford,
ON_Canada
Hey everyone!
I've tried to use this link but it wont work for me:
Guide to setting up your car for road racing (1G):
Tech Guide: 1G Road Race Setup - DSMtuners
I've basically got a stock '91 Eagle Talon Tsi awd 5spd. I've done all the maintenance and gotten the car running and shifting nicely now and want to take it on a road course in 4 days, Friday Aug 29 2014!!
MY QUESTION IS:
What part/s should I install now to give me the best results for my first time out or will it even matter right now?
Track web site:
http://www.torontomotorsportspark.com/raceway/videos.php?id=8
The car has been lowered but I don't know with what components. Possibly KYB
I bought and installed some aluminum rims fitted with Maxtrek ingens 235/45zr17 tires.
I've installed a front upper strut bar.
The air can has been hacked and the bcs restrictor has been removed.
I've installed a 190 fuel pump.
I've installed a boost gauge and was getting 7psi but am now up to 9psi after fixing some leaks.
I'm looking to buy a boost controller for sure before track day!
PARTS I HAVE:
I have a fmic and pipes.
I have a new stage 2 Exeddy clutch and machined lightened stock flywheel.
I have 550 injectors.
Polyurethane tranny bushing.
STUFF I HAVE BUT CAN'T USE YET.
I have a 16g turbo but needs a rebuild so thats out for this week.
I have a 3' down pipe with flex pipe down to the cat.From the cat down it would be all stock exhaust at this point.
An Evo Maf don't ask me from what year. I don't have a way to hook it up or use it yet. #'s on it are: 609 E5T06071
The cams out of that same Evo.
And a set of adjustable cam gears.
QUICK THINGS I COULD DO:
Remove the A/C belt, doesn't work any way.
Remove the balance shaft belt.
Empty the trunk, tire, jack, carpet, ect.
Adjust tire pressure, but to what psi????
What else???
MY QUESTION IS:
Track web site:
PARTS I HAVE:
What else???
