2G Tach jumps around
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
Where does the tach in the instrument cluster get it's signal from? Mine jumps around but while logging it in link it doesn't.
So the white wire goes directly to the tach from the ptu?
Coil pack>PTU>ECU>Dash
Well the ecu is getting a good signal or link wouldn't be showing smooth rpm increase. What pin does it come from ecu and go to tach?
Speedo kinda bounces a little. What fuse block you referring to the one in the cab under gauges? Also have an issue with the lights getting brighter when I rev the car up but not sure the problems are related.
Pin 58 on the small plug should be tach signal
Take that back speedo is all jacked it just bounces from 10-20 no matter how fast ya go.
Well wasn't the fuse block. Turns out that the power wire to the starter got smashed and had been exposed and was shorting out and had melted through some of the wires around it. Once i repaired it and the 4 wires it burnt up all my problems went away.
