Aaron_FTT
- 43
- 0
- Jun 27, 2014
pueblo,
Colorado
So I have a couple issues. First of which is the aem wideband in my car. After removing and replacing the tranny, I had trouble getting the car started. Starter was connected properly but refuse to turn. Seemed like there was zero power being sent to her. I decided to just wire in a push button so i could get it started and get her home. The car started but both my wideband and oil pressure gauges decided they didn't want to work. I'm concerned about how the wideband works with the ecu in particular. Is it just displaying my afr, or is it helping my ecu make decisions? The car seems boggy but idk if that is a result of something in the wideband loop or if it's because the e85 in my tank has been sitting for almost two months. The car hasn't thrown any codes my way so I almost want to assume the o2 is fine but I'm not nearly qualified to start making such assumptions.
I tried to be thorough but this is my first car with a wideband and I didn't install it so I'm not entirely sure if or how it affects everything or why it's just stuck at 14.8 all of the sudden.
