lou schmouder
- 271
- 0
- Jun 17, 2008
dalton,
Georgia
trying to find info on machine work on 2.3 6 bolt wit 7 bolt head
Seems like all the DFW DSMers recommend Watt's Shop https://www.facebook.com/pages/Watts-Shop/139433072803037I am actually trying to find a place that rents them as the shop here doesn't do enough 4g63's to invest in buying one.
...and I'm sure there's a machine shop in St. Louis that regularly rebuilds 4g63's, buying a torque plate is expensive if it's something you only use once or twice unless you can rent it out to other DSMers.
As for the OP, I'm sure someone that's from your neck of the woods could help you find a reputable 4g63 machine shop that has a torque plate. Just ask here in the South East region section OR get on http://www.sedsm.org/ and ask a local...
