jbeaton9292
- 847
- 72
- Aug 29, 2013
Sterling heights,
Michigan
Ok so i decided to try and make my own vent gauge pod for my wideband and boost gauge i used the vfaq to see how its been done gave me a idea of how to go about it
So what i did is took my old 1g a pillar dual pod and cut the gauge holders off angled them by running the on side of fiber cutoff wheel the glued them where i wanted them to vent bezel (hot glue) then i pull nylon leggings over it and glued it down where i needed to hold it all in place (after streched tight) then i used the fiberglass resin kit from walmart 17$ comes with resin hardener spreader stir stick fiberglass cloth (stuff stinks sobad ) and just slapped on a quick layer on the nylon so it will harden and add more so it cantleak through the nylon thats as far as ive made it so far pics attached
