Karma
- 142
- 2
- Mar 12, 2006
Sherwood Park,
Alberta_Canada
The title of the topic is a little misleading, wiring the gauge is easy as pie. However, im trying to find a way to run the wiring to the sensor from inside the car. AEM says to mount the sensor at least 36'' from the exhaust ports, which basicly leaves me mounting it at the end of the downpipe. But I can't find a way to run thw wiring down the back of the engine without it rubbing on either the steering system, or CV's. Is there a pre drilled hole in the floor somewhere I dont know about.
How / where did you mount your wideband. And how did you run the wiring.
