toppertopper
- 444
- 0
- May 14, 2009
edmonton,
AB_Canada
when the clutch is pressed there is no noise , when the clutch is released its grinding ..I have changed the master the slave , and the tob 3 times with the oem , i have seen jacks video ,..Is it not adjusted properly?.., when i adjust it some its like there is no clutch cant get into gear ..How it is now i can catch every gear perfectly just has the , grinding noise of the tob ...flywheel and pp is proper also had it checked 3 times
Na transmission / na flywheel / na act 2600 pp / na act 6 puck ridged race disk / oem tob x3
