Rock2610d
- 255
- 4
- Jan 22, 2013
Cheyenne,
Wyoming
I have a new OEM style (aftermarket) radiator. A new Gates water pump. A new OEM (Mit) 180 degree thermostat. OEM fans work perfectly, coolant fan comes on at 210 degrees and shuts off at 200 or so. AC fan comes on with AC. All factory deflectors are in place and functional. I have also put tin over the factory holes next to the radiator. I still have factory SMIC....no front mount.
Engine runs at 200 to 206 degrees on highway, and will go to 213 at idle and slow speed driving. Is this normal?
