Slo2gn
- 68
- 6
- Apr 27, 2014
Honolulu,
Hawaii
I have a 97 GST with a stock T25.. I noticed about a 3 weeks ago that I was smoking any time I was decelerating or just before i would come to a complete stop. It happend just after I installed the Megan racing catless DP... So I figured the turbo was on its way out so I ordered from GpopShop a stock t25 rebuild kit and rebuilt the turbo. I had no problems rebuilding it. (Note the car was Leaking oil at the Oil pan at the time) Also my Motor has a full rebuild on it with less than 250 miles.. (Full gasket kit New pistons Rods, oil pump valve seals, HG, ECT.) after Installing the turbo and a new oil pump gasket I went for a slow drive got into 5psi in 2nd gear and decelerated and still smoking WHITEish Blue ish smoke out of the Exhaust. However when I parked I still had a slight leak near my oil pan..
Is my turbo starving for oil? I am lost..
