Vendor Announcements: Special sales, group buys, and product announcements from our parts retailers and our other supporting vendors. We encourage all members to read and submit vendor reviews as well.
The Fuel Injector Clinic 1100cc Injector is a saturated / High Impedance Ball & Seat Injector. This 1100cc fuel injector provides great trailing throttle response and minimum pulse widths resulting in a perfect cold start and idle. And, it will work with E85 or other high performance fuels. The FIC 1100cc fuel injector will fit to Jetronic harnesses. (Resistor pack removal recommended when applicable.)
This new Fuel Injector Clinic 1100cc/min @43.5psi (3Bar) high impedance injector is 22 percent larger than FIC’s similar 900cc injector (also called the 1000cc injector by others) when flowed with calibration fluid, n-heptane or similar.
Important note: These fuel injectors are high impedance and do not require the use of a resistor box. If the vehicle in which this product will be used came with a resistor box from the factory (DSM / Evo / Etc.) you will need to remove that resistor box for these to function properly! Please feel free to contact us with any questions or concerns.
Injector Dynamics is a Strategic Alliance between Yaw Power Products and T1 Race Development and was created to bring Yawpower's dynamic injector characterization technology to the public. Previously this service was only available to tuners in the high end racing industry. Injector Dynamics prides themselves on providing the absolute best fuel injectors available. They back this claim by providing data and technology that absolutely no one in the industry can match.
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths. In addition to receiving tightly matched injectors, you will be provided with dead time compensation values across the entire pressure and voltage range of the injector. This data will insure that the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
Application specific fitment is handled with the addition of various top hat adapters, and occasional machining operations. Standard fitment exists for most popular applications, and new fitments will be developed on request. All standard lengths and fuel rail bores are currently accommodated.
Not sure what size injector you need for your goals? Pm or call for help
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
