Welcome to DSMtuners - the largest Mitsubishi Eclipse, Eagle Talon, 4G63t and 420A DSM performance resource on the web
Login
Go Back   DSMtuners > DSM Forums > General > Vendor Announcements
You are browsing the site as a GUEST. Please login (or register) and gain the ability to post on our site and interact with other DSMers. You also get to browse the site with fewer advertisements. It is FREE to join!
Vendor Announcements: Special sales, group buys, and product announcements from our parts retailers and our other supporting vendors. We encourage all members to read and submit vendor reviews as well.
Reply
LinkBack   Thread Tools
Old 02-17-2012, 01:26 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Non-Supporting Vendor
MAPerformance
maperformance's Avatar
Tech Posts: 228
Photos: 4
Classifieds Rating: 31
Reputation: maperformance is more helpful than not
Send a message via AIM to maperformance
MAPerformance - Unbeatable Deals on All Mishimoto Products!!
That's right, now that you have that winter project moving along, there has never been a better time to address the old cooling system! The timing is perfect and the prices will blow your mind!
The Mishimoto performance aluminum radiator for the Mitsubishi Eclipse is designed and engineered to maximize cooling efficiency, boost engine functions, and most importantly protect your car from overheating. It is the ideal upgrade to your stock Mitsubishi Evolution radiator. Whether you drive your vehicle daily or take it to the track an upgraded cooling system is essential in maintaining the lifetime of your engine. The Mishimoto aluminum radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required. All Mishimoto radiators come with a 'no questions asked' warranty including accident protection.
Specifications
* Overall Size: 27.5" x 18.6" x 4"
* Core Size: 13.19 x 27.08
* Rows: 2
* Inlet: 1.4"
* Outlet: 1.4"
* Core Thickness: 1.57"
* Tank Wall Thickness: .08"
* Drain Plug Thread Size: (M16) .06"
* Drain Plug Thread Length: .047"
* Purchase Includes: Mishimoto Radiator 1 Year Warranty
About Mishimoto
Mishimoto radiators are constructed of lightweight high-quality aluminum. Each radiator is hand welded. If you look at the welds on our radiators compared to some of the others on the market, you will see superior craftsmanship. One major problem with aftermarket radiators is leaking from the outlet to the overflow reservoir. We use specially designed brass fittings and ensure a 100% leak proof radiator. All of our radiators are pressure tested, TWICE! Notice the billet aluminum fill neck is unlike any other radiator. You can jump up and down on it, and it will never break or crack!
OR if that doesn't keep you cool enough, you can step up to the new X-line series!
Maintaining a healthy cooling system is a top priority for any driver, whether you take your car to the track or drive daily on the streets. Each X-Line radiator application has 3 rows for a core that is 25% larger than standard Mishimoto radiator applications. The triple core design of the X-Line radiator allows more coolant to flow through the core for maximum cooling capacity. Each application is designed as a direct OEM replacement, with no customization required for installation. Made with 100% brazed aluminum, Mishimoto X-Line radiators are a durable upgrade for a lifetime of efficient cooling.
Features
* 3 Row Radiator
* 52mm Core
* 25% Larger Than Standard 2 Row Core
Mishimoto Silicone Hose Kit / Mitsubishi Eclipse 1990-1994 (DSM 1G)
Mishimoto silicone Mitsubishi Eclipse radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with an OEM replacement fit! Perfect for your Mitsubishi Eclipse.
Product Specifications
Interior Material: Heat-Resistant Embedded Fibers
Exterior Material: Silicone
Max Temperature: 330 F
Inner Diameter
Hose 1: 1.34"
Hose 2: 1.34"
Outer Diameter
Hose 1: 1.69"
Hose 2: 1.69"
AND
Mishimoto Aluminum Fan Shroud / Mitsubishi Eclipse 1990-1994 (DSM 1G)
The Mishimoto aluminum fan shroud kit for the Mitsubishi Eclipse is the ideal upgrade from your standard OEM shroud. All Mishimoto fan shrouds are made for a direct OEM fit and are significantly lighter than OEM shrouds. They will increase your cars cooling performance by delivering a significant amount of air to your radiator and driving out excess heat from your engine. Mishimoto fan shroud kits also safely secure the fan blades from any potential damage to other essential engine components.
Product Details
* Height - 16.3"
* Length - 27"
* Width - 2.5" (including fans)
Product Contents
* Aluminum Shroud
* (2) 12" Slim Electric Fan
* (8) M6X20 Screws
* (4) M6X16 Screws
* (8) M6 Nuts
* (12) M6 Plain Cushion
* (12) M6 Elastic cushion
We have radiators, shrouds, hose kits all in stock. PM me for special pricing.
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: BurdAtMAP|||||: 1-888-MAPERFORMANCE x 100|||||: Burd@MAPerformance.com
: The MAP blog - Get the inside track on what we're doing!|||||: Check us out on Facebook|||||: Follow us on Twitter
Visit maperformance's homepage!  View photos of this member's car
mark post as helpful recommend reputation points    Reply With Quote
Old 02-17-2012, 03:30 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
spooln4fun's Avatar
Tech Posts: 439
Photos: 6
Classifieds Rating: 9
Reputation: spooln4fun is more helpful than not
Send a message via AIM to spooln4fun Send a message via Yahoo to spooln4fun
I'll take a pm for the shroud and radiator please. Just curious on price zip is 45714
____________________________
Owner of Mr. Panda
Old 02-17-2012, 07:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
mitsukid82's Avatar
Tech Posts: 30
Photos: 1
Classifieds Rating: 2
Reputation: mitsukid82 is an unknown
Send a message via MSN to mitsukid82 Send a message via Yahoo to mitsukid82
pm sent
Old 02-17-2012, 08:23 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
RayRay32's Avatar
Tech Posts: 110
Classifieds Rating: 8
Reputation: RayRay32 is an unknown
Don't forget the mishimoto magnetic drain bolt ... Thank you guys
Old 02-17-2012, 10:15 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
danieltovar's Avatar
Tech Posts: 193
Photos: 1
Classifieds Rating: 0
Reputation: danieltovar is an unknown
pm sent
Old 02-18-2012, 02:21 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Moe707's Avatar
Tech Posts: 0
Photos: 7
Reputation: Moe707 is an unknown
PMd
Old 02-19-2012, 06:48 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
dsmboost84's Avatar
Tech Posts: 110
Photos: 4
Classifieds Rating: 1
Reputation: dsmboost84 is an unknown
Pm sent
Old 02-21-2012, 08:33 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
MAPerformance
Tech Posts: 228
Photos: 4
Pms replied
Old 02-23-2012, 08:47 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
PerfectStorm's Avatar
Tech Posts: 45
Classifieds Rating: 10
Reputation: PerfectStorm is an unknown
Send a message via Skype™ to PerfectStorm
So this blow out special is only for the 1G guys?
Old 02-24-2012, 09:09 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
MAPerformance
Tech Posts: 228
Photos: 4
No not at all where did you see that?
Old 02-29-2012, 12:56 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
MAPerformance
Tech Posts: 228
Photos: 4
Pm me for a great deal!!!
Old 03-06-2012, 09:55 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
crackajak18's Avatar
Tech Posts: 10
Reputation: crackajak18 is an unknown
Send a message via AIM to crackajak18 Send a message via Yahoo to crackajak18
Pm
PM sent
Marc
'98 GST
Light modder
Old 03-06-2012, 10:34 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
daplatano91's Avatar
Tech Posts: 313
Photos: 2
Classifieds Rating: 5
Reputation: daplatano91 is pretty helpful and trustworthy
Price on x line Honda half rad shipped to 18202
-Frankie-
Old 03-06-2012, 11:42 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
MAPerformance
Tech Posts: 228
Photos: 4
pms coming your way
Old 03-07-2012, 06:08 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
Proven Member
dsmTripp's Avatar
Tech Posts: 239
Photos: 10
Classifieds Rating: 12
Reputation: dsmTripp is an unknown
Send a message via Yahoo to dsmTripp
Pm for radiator shroud and hose for 2g to 13607 zip please
97 gst spyder~building
95 gsx~donor/parting out
Visit dsmTripp's homepage!  View photos of this member's car
Old 03-07-2012, 10:17 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
MAPerformance
Tech Posts: 228
Photos: 4
Pm's Sent!!!
Reply
Bookmarks
Thread Tools
» Recent DSM Photo
» Current Poll
How many times have you been to the Shootout?
1 - 39.86%
167 Votes
2-5 - 41.77%
175 Votes
6-10 - 10.50%
44 Votes
11-15 - 3.10%
13 Votes
16-20 - 4.77%
20 Votes
Total Votes: 419
You may not vote on this poll.
» Online Users: 725
206 members and 519 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
© 2014 DSMtuners.com - All Rights Reserved
DSMtuners is not affiliated with Diamond Star Motors. The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, and associated logos are trademarks of Diamond Star Motors, Mitsubishi Motors, and Chrysler Corporation. No, we do not hand out car sponsorships.
