Login
Go Back   DSMtuners > DSM Forums > General > Vendor Announcements
Vendor Announcements Special sales, group buys, and product announcements from our parts retailers and our other supporting vendors.
Reply
LinkBack Thread Tools
Old 11-02-2009, 04:21 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
DSMtuners Supporting Vendor
Jackson Auto Machine
JacksonAuto's Avatar
Tech Posts: 30
Classifieds Rating: 0
Reputation: JacksonAuto is more helpful than not
Inside a JAM shortblock
In this thread we will show you what goes into EVERY shortblock build that we do. Every engine is completely balanced and blueprinted, and here we will show you how. This is intended to be a technical thread that shows what goes into a properly built engine shortblock.
------We first start with the engine block, either our customer supplied block, a good core or a brand new one. The first step is to strip it and placed into our soak tank to thoroughly clean it. Used blocks are Magnafluxed inspected to check for cracks and visually inspected for other damage or imperfections. The cylinder bores are measured and also sonic tested to make sure there are no thin spots in the casting. Once the block has passed these tests, a brand new set of ARP main studs are installed and the main girdle is torqued in place to check the align bore. This is to ensure all the crank bore is in the proper alignment with one another from front to rear. ***We've inspected brand new engine blocks and found them to be out of spec and not usable! Once we know that the block is in good shape we can then proceed to machining it.
Now we check over the brand new crankshaft. Every crank is thoroughly washed, Magnaflux inspected, polished, mic'd and checked to make sure that it is straight and within the proper spec. We do not use or sell any "Crank Kits" or under sized cranks. All of our strokers are assembled with brand new cranks and are fully inspected forged steel cranks. Once the crank passes all inspections, it is balanced then final washed for assembly.
First, we modify the oil galley in the front of the block, it is deburred and micro-polished for increased oil flow. This also reduces the level of restriction of the oil caused by the casting flash in the OEM blocks.
The next step in machining the engine block is to square the deck surface. Once this step is complete the engine block is set on a machinist bar that is perfectly level ( >.001" ), it is also secured in place to prevent any shifting or movement. Then a cutter head slowly moves across the deck surface area, thus removing material so that the deck is perfectly square and with the proper surface finish for your MLS head gasket. This is extremely important because the next step, Boring, locates the cylinders off of this surface. If the deck surface area is not square and parallel then the cylinders will also be crooked.
Now we can bore the cylinder walls of block. To do this the block is set on a stand and rolled under the under the machine fixture where it is lifted into position. The "Boring Machine" that houses the cutter head is now perfectly square with the deck. This is why it's critical that the deck surface be squared and parallel with the crank- otherwise the cylinder bores will not be in perfect alignment with the crank. With the block in place, the cutter head will move down through the individual cylinders removing material to the proper spec.
Once the cylinder walls of the block are bored, the cylinder walls are then 4 step Torque Plate honed using ARP head studs. This is where the final wall finish is applied to the cylinders based on the type of piston, rings and also the engines intended application (high boost, race only, N20, etc.). We install the main girdle and ARP main studs, all is then torqued to the proper spec before it is placed into the Rottler Power hone machine. We then install a precision made Torque Plate and the ARP head studs. By using a torque plate this simulates the cylinder head, the cylinder walls will be perfectly round when the head is installed on the block for use. If you were to hone the engine block without a Torque plate, the cylinder walls will distort when the head is bolted down, leaving the cylinder out of round. This will cause a loss of power, poor ring life and over all performance loss. A proprietary series of precision hone-stones are used to achieve the proper cylinder size and wall finish. A steady stream of clean honing oil is delivered while honing the cylinder walls, this is to lubricate and to keep the cylinder walls flushed of materials that has been removed.
Now that the engine block is fully machined, it is once again washed and inspected to make sure that it is 100% free of any contaminants. Then the piston oilers are installed, a brand new galley plug and freeze plugs are also installed, the block it then put on an engine stand to be mocked up. We start by checking the bearing clearances of the connecting rods. The rods are torqued in a special Rod vise to avoid damage and the housing bore is measured with a dial bore gauge to make sure that it is round and within spec. The bearings are then installed and clearances are measured to .0001" and if they are not in spec they are corrected. The piston pin bores are also measured in both the piston and connecting rod with the same dial bore gauge to .0001". Using a Sunnen pinfitting machine we then apply the proper surface finish to both the connecting rods and piston pin bores. The side clearance of the rods is also checked and corrected, if necessary. This is a measure of the clearance between the side of the rod and it's journal. Once the connecting rods are checked, we then proceed to check the main bearing clearances. The main bearings are installed and the main girdle is torqued in place. We also use the dial bore gauge here as well, to measure the inside diameter of the bearings with precise accuracy.
Once all bearing clearances are checked and verified for accuracy, we then disassemble everything for the final cleaning of the rotating assembly. All of the parts are final washed and prepped for the assembly. All components are laid out in the exact order inside of our dedicated assembly room. This is a spotless room where every engine is assembled with no chance of contamination. Nothing enters this room without a trip through one of our washers, including us! The main bearings and the crankshaft are installed and the endplay is measured and recorded on our engine spec sheet per customer. Pistons and the connecting rods are then final assembled. Each set of the piston rings are file fit to a particular cylinder, and clearanced per customer application-intended use, the rings are then installed on the pistons, pistons and rods are then installed using proper lube, the connecting rods are then installed into the engine block using stretch, not torque as this is the most accurate way to tighten these bolts.
We also modify the balance shafts for use in all of our strokers. The shafts are modified for proper clearance.
Now you have a precision machined - Blueprinted shortblock ready for use. If you have any questions, feel free to ask.
____________________________
Home of the First 8 Second 4G63 Engine
Last edited by JacksonAuto; 11-07-2009 at 07:28 AM. Reason: Improper wording and photo
Visit JacksonAuto's homepage!
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 11-02-2009, 05:11 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Tech Posts: 72
Reputation: t25fury is an unknown
so you guys machine the counter lobes off of the balance shafts as opposed to doing the bse application ? I like the idea,is it only for strokers or all your 4g63 blocks get this treatment ? is this mainly done to keep oil pressure at normal levels as the bse process tends to raise oil pressure quite a bit ?
edit: oops just reread that its done for stroker clearance,old man eyes
Old 11-02-2009, 07:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
DECODER22's Avatar
Tech Posts: 123
Classifieds Rating: 4
Reputation: DECODER22 is more helpful than not
wow very impressive its hard to find people that actually take their time and go threw everything
Old 11-02-2009, 07:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
dan2288's Avatar
Tech Posts: 499
Classifieds Rating: 9
Reputation: dan2288 is an unknown
can you guys PM me a price quote to micro polish a crank and to check it to make sure it is good and mic the journals to make sure they are within spec. thanks
built auto, Big 16g, FMIC, FP2 cams...
Old 11-02-2009, 10:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 50
Photos: 3
Reputation: DSMReviver is an unknown
brand new block? wait, do mitsu still make new block from the factory? i thought that they quit making them long ago. is this ture?
View photos of this member's car
Old 11-03-2009, 12:32 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Spoolin4Ever's Avatar
Tech Posts: 781
Photos: 2
Reputation: Spoolin4Ever is pretty helpful and trustworthy
Do you offer any warranty on stock rebuilds? Other applications as well or not?
Old 11-03-2009, 05:56 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Red Alert's Avatar
Tech Posts: 33
Reputation: Red Alert is an unknown
Well I know who I'll be contacting when my motor calls it quits! Amazing work you guys do!
Old 11-03-2009, 09:48 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
LocknessMonster's Avatar
Tech Posts: 84
Reputation: LocknessMonster is more helpful than not
Thats some nice machine work!
Old 11-03-2009, 10:38 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
New Member/Lurker
Tech Posts: 20
Reputation: onequikdsm is an unknown
Thats precision work for sure.
Old 11-03-2009, 05:19 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Tech Posts: 30
Quote:
That post was initially written up for an Evo forum. Those lucky guys are still able to get new blocks.
I have been BLASTED with PM's about the balance shafts so here is a bit of info on how we address them.
For most 2.0 builds, we simply eliminate them like most people do. A BSE kit with a stub shaft is installed. No big deal.
For ALL stroker builds we retain the shafts because the added stroke tends to amplify the vibration and harmonics that are created. The shafts have a bad reputation of spinning bearings but if the problems are addressed appropriately you will have years of trouble free service. The bearing clearance of the shafts must be proper or you will spin them just as you would spin a rod or main bearing if the clearances aren't correct.
With our shafts, your engines run smoother and last longer. The power benefit that a smoother engine provides negates the weight penalty of the shafts.
If you have any other questions, just ask.
Last edited by JacksonAuto; 11-07-2009 at 07:20 AM. Reason: Auto-merged with previous post to prevent "bumping"
Old 11-03-2009, 06:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 380
Reputation: DSM Jeff is more helpful than not
Seeing this definatly has me interested in choosing you for a rather stock build. Tired of not knowing what really goes on with "local" machine shops.
Visit DSM Jeff's homepage!
Old 11-03-2009, 07:20 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Tech Posts: 470
Reputation: slowgsr is more helpful than not
sir, do you do your line honing of the mains, as well as the inital bore with a torque plate and proper hardware (studs/bolts, headgasket) installed?
Thanks.
11.2 @ 130mph 1.9
11.1 @ 126mph 1.6 (less power)
Old 11-03-2009, 07:31 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Tech Posts: 30
We do align honing if necessary. All of our builds use main studs so we check the line bore of every block with them. Sometimes the block will be at one end of the book spec and since the studs pull different, they will sometimes pull the bore out of spec. If this is the case the block is align honed with the studs. Every block is plate honed with the fasteners and gasket that the owner intends to use. If he's going to use bolts and a factory gasket, that's what we use. If he's using studs and an MLS gasket we will use them instead.
Does this answer your question?
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
sunroof jam? 90T5I Newbie Forum 6 08-14-2008 03:14 AM
JAM Valvetrain alex Newbie Thread Graveyard 3 08-12-2006 06:19 AM
Jam Vs Magnus! dsmjay Bolt-on Tech 8 03-17-2006 08:51 AM
Jackson Auto Machine (JAM) shortblock nazthug Cylinder Head & Short Block 17 06-06-2005 08:12 PM
springbreak jam DOHCSIDE BOOST The Hangout 1 03-03-2004 04:11 PM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
Possibly buying a new 1G
by: booostedGSX
Details of build
by: Clutch GSX
» Recent Tech Threads
Title, Username, & Date
1980's HKS bov
by: bransonauction
Big problem need help asap
by: Niteninja01
looking to buy a nice talon awd, need help
by: dj99877
CeddyMod v1 (EcuFlash)
by: Ceddy
dsm link maft info needed
by: hondaslayer1
» Latest Gallery Photo
User icet34
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 33.33%
6 Votes
15 Votes
5 Votes
Total Votes: 18
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
