First the engine:
4G63 6 Bolt Block *honed with torque plate*
2.4L Crankshaft
85.5mm Bore (.020 over)
Eagle H-Beam Rods
Wiseco Forged Stroker Pistons
New Topline Front Cover w/ Oil Pump Gears
Balance Shaft Eliminator Kit
New Oil Squirters
New TRW Water Pump
Motor Mount Driver Side
Cometic Head Gasket
ARP Head Studs
ARP Main Studs *Block Line Honed*
Power Enterprise Timing Belt and all NEW tensioners *Fully Installed and Timed*
Unorthodox Racing Ultra Cam Gears
HKS 264/272 Cams
4G63 Oil Pan
Oil Pickup Tube
100% Hot Tanked
Fully Pressure Checked
Competition Valve Job
HKS 264/272 Cams
6 Hours of port and polish work (minimal porting - mostly cleanup work)
New Valve Stem Seals
Stainless Steel Swirl Polished, and Undercut Valves
New Valve Guides
New Revised Lifters
Crower Springs
Crower Titanium Retainers
Fully Decked Head Surface
New Stainless Steel Exhaust Manifold Studs
Black Painted Valve Cover
1G Intake Manifold
FIC 950cc Injectors
FIC High Flow Fuel Rail
$5200 for everything listed and in the picture
If you don't need some of the items pictured let me know and we can negotiate a little lower price.
Also, we have a TRE brand NEW Race Trans. Here are the specs:
Factory Brand New 1990 AWD Transmission
*TRE race model specs performed*
23 spline output shaft
Quaife front LSD
4 spider center diff w/ thrust bearing upgrade
Cryogenic Treatment
Double synchro ever gear
Every other race option available has been done to this trans
This transmission was $4400 brand new. Buy it now for only
$3200 while it lasts! Here are some pictures:
