We are now offering a free set of plugs with the purchase of any ignition wires from our web store!
Here is what we have available right now.
NGK wires Available for 1g and 2g.
Utilizing a construction method known as "variable pitch" wire winding, these wires create resistance to radio frequency interference. With materials similiar to bullet-proof vests, high quality EPDM and Silicone, corrosion resistant nickel-plated terminal ends, these are made to fit perfectly and resist high temp, oil and chemical damage. The wires are numbered to correspond to the cylinder.
Magnacore wires
Stainless Steel wire under aerospace grade silicone rubber with a heat resistance up to 1,000 degrees. Single layer construction prolongs the jacket's insulating ability by conducting extreme heat away from hot-spots that occur near over-the-limit heat sources. We use the 8.5mm for most applications or pick up the 10mm for even more spark!
MSD wires
MSD's Super Conductor wires for your 2G (95-99) are direct replacement spark plug wires and offer greater spark for a smoother idle, better gas mileage, better heat resistance, and longer life. The MSD Spark Plug Wires are 8.5mm thick and low resistance without electronic interference, giving you a smooth clean spark everytime!
These can be found here..
Street Tuned Motorsports - DSM Ignition <--Click to buy
Thanks
-Emery
STM - Street Tuned Motorsports.com - Rochester NY
585-507-8122
