04-12-2008, 09:21 AM
#211 (permalink)
Proven Member
Region: Tri State
Quote:
Originally Posted by CoachDavis
JMFabrications can you please answer the previous questions about the effectiveness of these shields? I am interested in purchasing one even though I missed the gp.
x2
I'm waiting to hear back from them too. I'm assuming their busy.
Offline
04-12-2008, 09:46 AM
#212 (permalink)
Proven Member
Region: Southeast
This my sound stupid but you do have the FP manifold and you are turbo right?
Your avatar says otherwise...
As far as effectiveness; im running without a heatshield on my FP right now and before the FP mani went on I had a evo3 manifold with a sbr heatshield and the engine bay temps have sky rocketed.
If im sitting in traffic for too long or at idle, my entire engine bay will be heatsoaked.
This much heat could detinitly effect the tune in terms of knock threshhold and air density. Luckily i have a cold air intake ran outside the engine bay or my IAT's would be up there.
Not to mention running with no heatshield provokes altenator or P.S. pump failure.
It would only seem logical to run a heatshield on a daily driven car.
I missed the group buy but i am ordering mines today.
Screw the bling factor, Its going to be a hot summer and i wouldnt want to be without one of these while driving as much as i do.
____________________________
((Jay))
E316G - 6bolt/4bolt
Offline
04-12-2008, 10:44 AM
#213 (permalink)
Proven Member
Region: Mid Atlantic
It takes 5 hands to install this sucker!... lol
Whats the trick?
98 GSX A/T
Jake
Offline
04-12-2008, 11:06 AM
#214 (permalink)
Proven Member
Region: Gulf Coast
yay mine came, and it looks gorgeous! Kinda curious as to where to put the sticker?
Offline
04-12-2008, 11:08 AM
#215 (permalink)
Proven Member
Region: Southeast
Quote:
I always put all my stickers under the bottom side of the hood like the old muscle cars do.
Cant see myself putting any of that stuff on the outside of the car. That would get ricey real quick...
((Jay))
E316G - 6bolt/4bolt
Offline
04-13-2008, 06:53 PM
#216 (permalink)
Proven Member
Region: Western Canada
Here's mine installed:
Tom
-Tom
-Red 95 Talon TSi AWD w/ Built 7-bolt
Offline
04-14-2008, 07:53 AM
#217 (permalink)
Proven Member
Anyone got a picture of theres installed with the j-pipe? Does it touch your j-pipe? I have mine on, it just doesn't look right. I am going to mess with it tonight as I was in a hurry to get it on there.
98 GSX A/T
Jake
Offline
04-15-2008, 08:19 PM
#218 (permalink)
New Member/Lurker
Region: Pacific Northwest
Got my polished one yesterday. Looks great! I cant wait to put her all on!
Offline
04-15-2008, 10:18 PM
#219 (permalink)
DSM Wiseman
Region: Tri State
Finally got the damn thing on !
~Tom
1995 TSi AWD - BB5031RE
Offline
04-16-2008, 12:37 AM
#220 (permalink)
Proven Member
Region: NorCal
Quote:
Whats the trick?
I started with one half of the "O" assembled and hooked around the internal gate's waste gate actuator without the heat shield in the mix (at first)... line up the other long bolt and start with it part way through the actual heat shield... one it's started, then back out the first long bolt and rethread it through the other half of the heat shield.
Once that happens (and after a few heat cycles) then you might end up in my boat with this:
V V V V V V V
Offline
04-16-2008, 12:39 AM
#221 (permalink)
Proven Member
Region: NorCal
Guess this was missed... Anyone else run into this?
Quote:
Originally Posted by BoostedTalonTS
JMFabrications,
The ONLY question I have is what's the secret to getting those SS bolts to keep from backing out? -I've tried replacing the lock washers, and High temp LockTite... they still seem to backout no matter what.
Offline
04-16-2008, 06:55 AM
#222 (permalink)
Proven Member
The one I'm using is actually JM's original prototype. Mine has held up just fine and Ive had no issues with heat in the engine bay. I do have one of the bollts backing out on occassion, but that is due to my own fault as I lost the lock washer. The other bolt that still has the lock washer remains snug.
Offline
04-16-2008, 10:22 AM
#223 (permalink)
DSMtuners Supporting Vendor
JM Fabrications
To be honest I have never run into this issue, the lock washers will usually prevent this from happening. If you still have issues down the road PM or email me and I can send you some new lock washers or even locking nuts to put on the backside.
Thanks,
Jim
Offline
04-22-2008, 12:24 AM
#224 (permalink)
New Member/Lurker
Region: Southwest
Jim, I haven't had any heat issues yet with my car. But I've only owned the GSX for a month, and being this is AZ the heat is cming soon and I want to be prepared. So I've checked all the post to see if anyone has hard numbers as to the effectiveness of the shields. But can't fing anything but people happy to have more shine under the hood. Please help. Do they lower underhood temps 5 degrees, 10 degrees, etc? Thanks.
Offline
04-22-2008, 12:45 AM
#225 (permalink)
Proven Member
hey Jim is this still going on? or am i to late?
awaiting the arrival of my new FP setup figured i'd get another pretty shield from you all. last one i have is now a show piece on a friends awd spyder. def catches alot of attention too
Jeremy (jpick)
Offline
04-22-2008, 06:17 AM
#226 (permalink)
DSM Wiseman
Region: Tri State
I finally got the chance to go to the track with the manifold and drive it around a bit. With the heat shield on, there is a definite loss of underhood temps. The underside of my CF hood used to get blazing hot and would seep over towards the power steering area, but with the shield, it has drastically reduced the amount of heat coming from the manifold.
~Tom
Offline
04-22-2008, 06:50 AM
#227 (permalink)
JM Fabrications
Yes the heatshield is designed to lower underhood temps around the manifold area so that it will not melt parts close by. I would say easily by 20°+, it will vary with every car.
Sorry but the GB ended a few weeks ago.
Offline
04-22-2008, 11:57 AM
#228 (permalink)
Proven Member
thats cool thanks jim. i'll just pick one up from the website then haha
Jeremy (jpick)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
