01-17-2008, 05:40 PM
#1 (permalink)
DSMtuners Supporting Vendor
MAPerformance
Region: Midwest
Introducing MAPerformance Ultimate Duty Billet Steel Connecting Rods Just $599.99!
Click the image below to pick up your set today!
Stop waiting for the competition to fit your motor build into their schedule! These rods are readily available and at just $599.99 shipped the price is right!
What Is Ultimate Duty?
Manufactured exclusively for MAPerformance by Howards Racing Components we developed these connecting rods to fulfill the needs of the hardcore enthusiast. Designed to handle 1000+ horsepower in a 4 cylinder application these truly are ultimate duty connecting rods!
Research & Development
The research phase for these connecting rods consisted of a process called Finite Element Analysis which helped us to determine the weakest points of the factory connecting rod design. Using that information we developed a prototype using state-of-the-art CNC equipment that included the finest high nickel AQ4340 billet steel material, Ampco 18 bronze wristpin bushings, Manton alignment sleeves, and massive 7/16" ARP 2000 series fasteners. In the final development phase the prototype was heat treated, fully stress relieved, and shot peened to ensure that no stress risers or surface imperfections remain. The end result: A product that we feel is the strongest and most reliable steel connecting rod available on the market for this application.
Click here to pick up your set today!
____________________________
Phone: 763-545-3800
www.maperformance.com
Offline
01-17-2008, 11:13 PM
#2 (permalink)
Proven Member
Region: NorCal
What is the weight on these rods?
-Edwin
550whp 34psi Sean Burgess Tune
Offline
01-18-2008, 09:16 AM
#3 (permalink)
MAPerformance
Region: Midwest
652 Grams
Phone: 763-545-3800
Offline
01-18-2008, 11:20 AM
#4 (permalink)
Proven Member
Region: Central Canada
Chris, how do these compair to say crowers? I mean like weight, strenght, etc etc.
Offline
01-18-2008, 11:53 AM
#5 (permalink)
Proven Member
Region: Midwest
Anything longer than 150mm?
Offline
01-18-2008, 11:55 AM
#6 (permalink)
MAPerformance
Region: Midwest
I can't track down the weight of the Crower's but these should be as strong if not stronger. These guys weigh about 30 grams less than the normal weight Pauter, but with the Finite Element Analysis that was performed in the research phase these rods are, in our opinion, the perfect balance between reciprocating weight and overall strength.
Chris
Phone: 763-545-3800
Offline
01-18-2008, 11:57 AM
#7 (permalink)
MAPerformance
Region: Midwest
They are only available in 5.900" at this time, but can be made to order in other lengths. Please let me know if you would like pricing and a timeframe!
Chris
Phone: 763-545-3800
Offline
01-18-2008, 11:59 AM
#8 (permalink)
Proven Member
Region: Midwest
I sure would. 162mm and 7-bolt.
Offline
01-18-2008, 02:27 PM
#9 (permalink)
MAPerformance
Region: Midwest
I will check into it and get back to you thanks!
Chris
Phone: 763-545-3800
Offline
01-18-2008, 02:30 PM
#10 (permalink)
MAPerformance
Region: Midwest
I'm surprised no one has mentioned the 7/16" rod bolts, they make the 3/8" versions the competition uses look weak
Phone: 763-545-3800
Offline
01-18-2008, 08:31 PM
#11 (permalink)
Proven Member
Region: Western Canada
I was just about to reply regarding that, actually -- the rod bolts, that is. These look like a hell of a rod if you're wanting to build a high-rpm monster. You can never have rod bolts that are too strong when you're licking 10,000rpm and beyond.
Offline
01-19-2008, 08:50 AM
#12 (permalink)
MAPerformance
Region: Midwest
Exactly
Phone: 763-545-3800
Offline
01-19-2008, 08:51 AM
#13 (permalink)
Proven Member
Region: Mid Atlantic
Is this the same Howards that does a ton of things for V8's?. Do these use standard bearings? If so they are def. high quality! Sounds great!
Offline
01-19-2008, 08:55 AM
#14 (permalink)
MAPerformance
Region: Midwest
Yes they are, and yes they do
Phone: 763-545-3800
Offline
01-21-2008, 01:24 PM
#15 (permalink)
Proven Member
Region: Midwest
Quote:
Chris
Anything yet?
Offline
01-21-2008, 02:35 PM
#16 (permalink)
MAPerformance
Region: Midwest
I haven't got a price on the custom set yet but I will be sure to let you know as soon as I do!
Thanks,
Chris
Phone: 763-545-3800
Offline
01-28-2008, 09:00 PM
#17 (permalink)
Proven Member
Ive used howards aluminum rods before and they are great.any chance they make these in aluminum?
Offline
01-29-2008, 08:39 AM
#18 (permalink)
MAPerformance
Region: Midwest
Checking into that as well! Thanks!
Phone: 763-545-3800
Offline
01-30-2008, 02:15 PM
#19 (permalink)
MAPerformance
Region: Midwest
Quote:
Aluminum is available and just $20 additional!
Phone: 763-545-3800
Offline
02-03-2008, 10:29 AM
#20 (permalink)
Proven Member
Region: Midwest
Last try for 162mm rods...
Offline
02-03-2008, 10:55 AM
#21 (permalink)
Proven Member
Region: Rocky Mountain
Whats the weight on the aluminum rods, and what aluminum is used exactly?
Offline
02-04-2008, 12:51 PM
#22 (permalink)
MAPerformance
Region: Midwest
Quote:
they did get back to me but for a one off custom rod such as this they would be almost $1000, let me know!
Chris
Phone: 763-545-3800
Offline
