12-10-2007, 10:56 PM
#1 (permalink)
DSMtuners Supporting Vendor
VIP Garage
Region: Mid Atlantic
New Brake Packages / Clutch Deals / Timing Kits are back!
hey folks,
Well it's been one hell of a crazy end to an eventful race season.
We've made some new brake kits to fit more people. You'll love these!
DSM Brake Kits now featuring genuine Power Slot slotted rotors!
We have taken all of the guess work out of putting together a street brake setups. We have bundled what we have found to be the best bolt on configuration for your DSM. We have recently started running this setup on two DSM race cars that are doing amazing.
In each kit you get:
Power Slot Slotted Front Rotors.
Power Slot Slotted Rear Rotors
Hawk HPS Front Brake Pads
Hawk HPS Rear Brake Pads
Russell DOT Approved Stainless Steel Brake Lines
90-99 FWD, 90-92 AWD Kit
93-99 AWD Kit
We also have clutch bundles that include the clutch, flywheel, ss clutch line and even fluid!
ACT has been a house hold name in the DSM community for years. We have bundled up their products into a no brainer solution for any DSM build up in need of a single disc clutch kit.
Our bundle includes the following parts:
ACT 2100 Clutch Kit w/ Street Disc (6 Puck available)
ACT Street Lite Flywheel
SS Clutch Line (Full master to slave line available for 2G's)
3qts. BG Syncrhoshift II
Click Here for more info
And we FINALLY have more of the timing kits in stock! These are a complete solution. Just click and get every part you need for a thurough timing service!
Our bundle includes:
Continental timing belt
Continental balance belt
OEM Mitsubishi tension tool
Continental power steering belt
Continental alternator belt
Continental a/c belt
GMB water pump w/ o-ring and gasket.
This combo is one we have used for years with tremendous success. We highly recommend you perform this service every 60k. This bundle saves you over $30 from buying these parts separate.
Click Here for more info!
As always thanks for your time folks and happy boostin!
Online
12-11-2007, 08:29 AM
#2 (permalink)
Proven Member
Region: Tri State
Any packages for the Gvr-4? Would like to upgrade.
Offline
12-11-2007, 09:40 AM
#3 (permalink)
Proven Member
Region: NorCal
I am interested in your brake kit for my 93 talon. When does the sale end
Offline
12-11-2007, 11:36 AM
#4 (permalink)
VIP Garage
shoot me a pm with what you'd like for the GVR-4. We can hook you up.
And the deal will go through the end of the month bud.
Online
12-11-2007, 06:30 PM
#5 (permalink)
Proven Member
Region: NorCal
End of the month? Dang
Offline
12-12-2007, 01:13 AM
#6 (permalink)
Proven Member
Region: NorCal
By chance are you guys offering the oversized Powerslot rotor with aftermarket caliper spacers that adapt to allow an OEM caliper to fit the larger rotor diameter?
-If so, I'd be interested in the 1g AWD front set FOR SURE ! -I already have an existing Power Slot setup but still need better breaking
Offline
12-12-2007, 01:15 AM
#7 (permalink)
Proven Member
Region: Southeast
is there any power slot rotors and pads for the rare 94 rear vented rotors ?
Offline
12-16-2007, 09:11 AM
#8 (permalink)
VIP Garage
thanks for all of the orders folks. All of the timing kits ordered this week are shipped.
Online
12-16-2007, 07:25 PM
#9 (permalink)
Proven Member
Region: NorCal
any response to my earlier post? (Post #6)
Offline
12-16-2007, 08:28 PM
#10 (permalink)
VIP Garage
I will verify both questions tomorrow as soon as i get to the shop tomorrow.
Online
12-17-2007, 09:11 PM
#11 (permalink)
Proven Member
Region: NorCal
Have you found a good place for 1ga guys to purchase the 93-94 dual piston calipers? If i buy the dual piston calipers, and mounting brackets, can you supply the correct "shims" that we need to have the brake pads the correct distance?
I want to buy this brake kit, but i wont do it with my stock single piston calipers. Ive found calipers for $64 each and i want to know if there is anything else i will need to make this brake upgrade complete.
Thanks, any help is appreciated, ive been looking at your brake kits for years and now i can finally afford to upgrade before the new season nets me more power that i will need to stop!
____________________________
-Danny
Online
12-17-2007, 11:01 PM
#12 (permalink)
VIP Garage
I tried calling powerslot to confirm availability and didn't get an answer. The computer shows a code that stands for discontinued but i'm not sure. I'll try to bother them again tomorrow to find out for you.
Quote:
unfortunately they don't.
You shouldn't need anything else bro. You just want to be sure that the new calipers come with the brackets and all. Most caliper replacements that are listed are just the actual hydraulic caliper alone.
Online
12-21-2007, 01:18 PM
#13 (permalink)
Proven Member
Region: NorCal
Quote:
Any news?
Offline
01-10-2008, 01:52 PM
#14 (permalink)
VIP Garage
Thanks for all of the orders guys.
More available.
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
