ARP Extreme Duty L19/H11 6 Bolt Head Studs In Stock And Just $299.99 Shipped!
Are you shooting for over 600whp? Planning on running more than 35psi? Tired of waiting on A1 Technologies?
If you answered yes to any of the above questions these custom studs from ARP are a great option. They utilize the same H11 tool steel for the studs, dubbed L19 by ARP, which has been proven to hold cylinder pressures present over 1000whp!
Sure, these aren't for everyone. The tried and true 207-4201 ARP head studs have proven themselves time and time again. However, the bar continues to be raised in regards to the 4g63 platform. It's almost as if you have to be in the 8 second range to be considered fast anymore! As such, many of us have set our goals higher and the standard ARP's just aren't going to cut it! Plus you won't have to replace these bad boys every time the head comes off! These will save you money in the long run!
We currently have 7 sets of these on the shelf, be sure to get yours while you still can as there is a 6-8 week build period for the next batch!
*The nuts and washers in this extreme duty kit continue to utilize a premium grade 8740 alloy found in the standard ARP kit as these are not the point of failure in regards to cylinder head lifting and head stud stretch. These also include ARP moly lube.
Can you order a set sans the washers/nuts. For those of us that already have the ARP headstuds the L19kit comes with STANDARD nuts/washers and we already have them
____________________________
Cory O.
'92 Galant VR-4
'94 TSi AWD Built
