Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Vendor Announcements
Vendor Announcements Special sales, group buys, and product announcements from our parts retailers and our other supporting vendors.
Reply
LinkBack Thread Tools
Old 08-20-2007, 11:48 AM   #1 (permalink)
DSMtuners Supporting Vendor
Car: '06 Evo IX
Region: Mid Atlantic
Classifieds Rating: (1)
Reputation: 11secDSM is an unknown
Dynatek plug and play CDI on SALE!!!
Sick of your MSD boxes failing? Dynatek has a proven track record in other markets and have now come out with plug and play CDI boxes for the 95-99 DSMs and the 2003-2004 Evo VIII!
We are the East Coast distributor for DSM and EVO Dynatek CDIs.
• Smallest Lightest CDI on the market
• Simplified Plug in harnesses for easy installs without need for tach adapters
• Over 189mJ delivered to the coil per spark, the highest of any on the market
• Over 500V to the coil primary
• Over 50kV to the coil secondary (assuming a 100:1 coil)
• Intelligent Spark Profiling (ISP) allows for less delay between successive sparks
• Spark Restrike up to 4500 RPM
• Provides this high level of output from as low as 8 Volts from the battery
• Works with any 2 coil OEM ignition, with or without factory ignitor (some systems may require replacement coils)
• Built in launch limiter, works from 2000-11900 RPM
• Built in fixed timing retard function
• Tach output
Technical specifications:
Operating Voltage: 8-20 Volts
Operating Current: 7.0A @ 10,000 RPM
Maximum Operational RPM: 18,000 + RPM
Ignition Inputs: 2 rising or falling edge
Ignition Outputs: 2 independent channels
Coil Primary Energy Max: 189+ mJ
Coil Primary Voltage Max: 500+ V
Restrike Window: 25 crankshaft degrees
Launch limiter input: Single wire, ground to activate launch limit.
Retard input: Single wire, ground to activate timing retard
Tach output: 12V square wave, 50% duty cycle
Dimensions: 4" x 4.6" x 1.4"
Weight: < 1.25 lb.
RETAIL PRICE- $399.99
SALE PRICE- $359.99!!!
Order online at http://jnztuning.net/proddetail.php?prod=DYNA_ARC-2a or give us a call at the shop. 215-997-6850
____________________________
-Chris
STOCK BLOCK, ECU, MAS
HTA 35r
502 whp
Offline
Related Auctions
Sponsored Links
Old 08-26-2007, 07:46 AM   #2 (permalink)
Proven Member
Region: Outside North America
Classifieds Rating: (6)
Reputation: mitsumissile is more helpful than not
I am interested in it. Can you ship it overseas? Thanks
Offline
Old 08-27-2007, 01:37 PM   #3 (permalink)
Car: '06 Evo IX
Yes, we can ship overseas.. I also replied to your PM.
-Chris
HTA 35r
502 whp
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11045194 seconds (73.01% PHP - 26.99% MySQL) with 9 queries
