Phantom knock source??
HIGHPSI4
809
11
May 11, 2003
Vale, North Carolina
As some of you may have read I am really having trouble with knock pulling all timing in my '90 AWD. So far I have changed in 3 ECU's, 2 knock sensors, 2 MAS, made a CAI, MCCC and colder plugs, etc. I have switched in a different o2 sensor and it has helped some. I still have bad knock below 2300 rpm and worse in 2nd, 4th and 5th.:confused:
I did talk to a Mitsu tech in Hickory that has worked on DSM's from the get go. He did some digging and found that the ecu looks and timing and o2 before it 'gives a knock signal'. If this is true, can the ecu generate a knock signal? Is this how the ecu pulls timing? If both are true then this would be a source of phantom knock. Everytime I change something the knock is gone for 5 - 15 minutes of driving and then returns. It is like the ecu 'learns' the new part and then adjusts itself and starts pulling all timing due to knock.:cry:
Please provide any feedback....
The most common cause of phantom knock is lifter tick. There is a 3rd revision set of lifters out there for about 7.75 each from a engine supply shop. Give them a call at 1888 855 9712. I swapped them in my 90 and it fixed 99% of my phantom knock. The other knock is when I hit bumps in the road so I'd say that it's my motor mounts or exhaust clanking around.
when i tore my 93 engine apart i had 2 or 3 bad lifters and with how much they moved i would imagine they created a lot of knock. Unfortunately i also think this might be your problem. As far as the ecu creating a phantom knock i have never heard of that before.
