THEDUKE
- 91
- Jan 23, 2003
Bristol,
Tennessee
I have this missing problem in the upper rpms. This happens when I ajust the fuel. If I go leaner or richer. There is only one point in the fuel mix that it will run & not miss.All my ignition is redone with msd wires,NGK plugs,New coilpack,MSD II box.I have had this problem with these injectors I am running.They are MSD 630 I can reemove them & the problem goes away.I only have the 450 to replace them with. When I get it where it dont miss with the 630 Knock,timing,o2,pulswith all look good. Could these injectors have a deadtime that will bairly work with the DSM.I bought them used & dont realy now what they are for. What brand & size would be good for my setup.I have been told that the 720 - 780 is about as big as I can use with the afc. I have the SAFC & a translator with 3 1/2 GM maf. It shows in the translator ajustments up to maybe 1100cc injectors. I know I will need big injectors later but could get by with the 720-780 for now.Does this sound like the injectors may be my problem & what brand to buy if it is.
