codym
- 636
- 7
- Dec 28, 2011
Amarillo,
Texas
I got a few things for the dsm with tax return
I've been having some issues with my 1g n/t MAF, so I went ahead and ordered a MAF-Translator, and picked up a GM MAF from a 2003 Impala at the local salvage yard.
Along with a wideband so I can use my SAFC more effectively.
I am working on a 91 3000gt VR-4 as a side project, these have 360cc Injectors from the factory vs 240cc in the n/t 1g's. I'll be putting 1250's in the VR4 for e85 setup, so I have these 360's as spare.
After reading how to set up your base injector size on the MAFT, I see the lowest value for base and aux is 0,0 - equalling the factory turbo dsm injector size of 450cc.
I assume you can not go below these values, for example Base: -9 Aux:0 (360cc)
How would I go about setting up the MAFT to function properly with these injectors?
I'll be setting up the Translator in cab, I will be using it for base tune, and the SAFC for fine tuning.
Thanks for any help/feedback!
