cbr600teardrop
- 262
- Jun 26, 2008
lancaster,
Kentucky
what psi should i run to get the most out of the 16g big turbo iv read some where between 20-25 psi does that sound right? ill send my dsm chip back off and have it remapped what fuel pressure should i run ifc 650cc i was going to run it at 55 psi that's at 80 to 85 % duty cycle @ 723cc at 8.1:1 compression ratio other mods listed in profile.
... Something else that made the 16g feel better is when I ran a cold air intake into the fender well w/ a gm maft blow thru setup, it held boost longer to redline after doing that. I wouldnt mess with the fuel pressure too much, on regular pump I think your 650s will be fine with a 2g fuel pressure. If you do increase it you can get more flow out of the injectors ( less from the pump) but you have to have the chip burned accordingly. But fwiw I run the n/t fpr with a 47psi base fuel pressure and 850cc FIC's and a HP 255lph. Anyways Just throwing out some ideas for you...
