Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 05-13-2008, 02:10 PM   #1 (permalink)
Proven Member
GSX93DSM's Avatar
Region: Mid Atlantic
Classifieds Rating: (0)
Reputation: GSX93DSM is more helpful than not
AFC settings for 750 injectors
I have afc,190 rewired fuel pump,and 750 injectors, gm maft. I have the afc set at 20%- at low throttle is that normal. It was at 0 but the car ran rough, leaned the afc out ran better is that a safe reading.
Offline
Related Auctions
Sponsored Links
Old 05-13-2008, 02:57 PM   #2 (permalink)
Proven Member
Twistaye's Avatar
Region: Southeast
Reputation: Twistaye is an unknown
Do you have a wideband and a logger? While doing that on one car may be safe, doing it on another could be disasterous. It really depends on your setup, you should get a logger and monitor your knock and a wideband to check your a/f. Doing so will help you tell if it's a "safe" combination. As long as you're not knocking and your a/f is in a decent range then you should have no issues, just make sure you log everything so you know if you're detonating your engine or not, don't judge it off the "butt dyno" gl
Offline
[posts] [gallery] [blogs] Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
750 injector afc settings GSX93DSM Tuning & Engine Management 1 04-14-2008 03:03 PM
need a starting point for 750 settings Spln_Hrd Tuning & Engine Management 0 06-09-2005 12:24 PM
1g's w/2g mas afc 550cc,650cc,660cc injectors post you afc settings? NJdsmguru Tuning & Engine Management 2 08-09-2004 11:06 PM
AFC settings for stock turbo and injectors? red98gst Tuning & Engine Management 8 01-18-2004 09:47 AM
S-AFC II settings for 650cc injectors Deathscythe Tuning & Engine Management 11 11-27-2003 12:12 PM
Page generated in 0.09860206 seconds (64.42% PHP - 35.58% MySQL) with 10 queries
