Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 01-13-2008, 03:14 PM   #1 (permalink)
Proven Member
whiteflash's Avatar
Region: Pacific Northwest
Classifieds Rating: (2)
Reputation: whiteflash is an unknown
Stuttering under boost, new log, check it out...
I just got the Evo 560's in and I'm having some difficulties getting it tuned. At around 5K rpm it starts stuttering really bad. Boost is set at 16-17ish
Mods are:
Ported 14b, Evo 560's, 190 FP, TB no cat, etc
SAFCII settings:
Low: -15% all the way across
High: 800 1600 2600 3000 3600 4000 5000 5600 6000 6400 7000
-15 -15 -15 -15 -16 -18 -18 -18 -16 -16 -16
Time Engine RPM Timing Advance Intake air flow rate Oxygen Sensor 1
1/13/2008 14:23 2250 29 15 200
1/13/2008 14:23 2335 30 28 160
1/13/2008 14:23 2535 22 48 900
1/13/2008 14:23 2843 9 89 940
1/13/2008 14:23 3343 8 107 940
1/13/2008 14:23 3804 9 124 940
1/13/2008 14:23 4367 9 144 940
1/13/2008 14:23 4796 11 157 940
1/13/2008 14:23 5234 15 30 900
Right about near 5000 its starts sputtering really bad so i let off. Any help would be greatly appreciated. thanks
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
stuttering under boost, sure its not a boost leak. GsxEcutioner Newbie Forum 14 09-08-2007 10:36 PM
stuttering after boost Duke901 Problem Diagnosis 22 05-08-2007 08:11 PM
stuttering under boost 94Talon2 Problem Diagnosis 31 06-05-2005 01:02 PM
Stuttering and bucking under boost Colossus Problem Diagnosis 3 03-07-2004 09:15 PM
Bucking/Stuttering while in boost? Benji Problem Diagnosis 14 11-10-2003 10:07 AM
Page generated in 0.10638404 seconds (61.49% PHP - 38.51% MySQL) with 10 queries
