Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 12-19-2007, 10:29 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: knightrider4 is an unknown
95 engine harness into a 97
I am in the middle of a 6bolt to 7bolt swap in a 97 talon and to make a long story short had to get a 95 harness. I wired everything in to put everything back into phase however the connector for the fuse box is not the same. I was wondering if anyone has done this before or maybe has a pinout of the 97 fuse box connector and a pinout of the 95 fuse box connector so i can wire in a new clip.
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
95 harness 97 ecu? BLACKpsiECLIPSE 420A Bolt-on Tech 4 05-09-2007 10:46 AM
Having Problems w/ 97 GST Harness in 95 GST..Help Please !!!! ShadeTreeDSM Problem Diagnosis 1 03-10-2006 03:38 AM
95 to 97 engine swap? SilverJester Problem Diagnosis 3 12-29-2004 07:33 PM
Page generated in 0.10391498 seconds (66.79% PHP - 33.21% MySQL) with 10 queries
