Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 09-16-2007, 02:49 PM   #1 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (0)
Reputation: jonezj is an unknown
dsmchips cam compensation
I recently purchased a new eprom socketed ECU for my 92 AWD and got a dsmchip burned for mods i was expecting to get done. Here's the list of settings for the chip:
rev limit - 8500
Fuelcut elim
Octane Value - 93
Check engine shift light @ 8000
Boost Gauge Conversion to Knock Sensor
AC Cutout
5500 RPM Stutterbox and No-Lift to shift
Fuel Injector comp - 680cc
Deadtime compensation (injectors are PTE 680's)
2g MAS Comp
Enhanced Closed Loop
Idle Speed -800rpm (or whatever recommended) running Compcam 272 equivalents
All of these mods match my current setup, except I did not get the 272's installed yet. Should I not use the new ECU until I get the Cams in? It might be awhile before I get to it. what does the chip change when taking cams into mind? is it dangerous to run the stock cams while the computer is compensating for 272's?
My car is running on the old stock ecu with SAFC, not yet adjusted to the 680's but set for 560s. I couldn't find any information at the vendors site or the forums upon searching.
Thank you!
Julian Jones
US Army, AF
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09625101 seconds (63.98% PHP - 36.02% MySQL) with 9 queries
