Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 09-15-2007, 05:44 PM   #1 (permalink)
Proven Member
Car: 90 Corolla
Region: Midwest
Classifieds Rating: (2)
Reputation: linksys42 is an unknown
EVOscan HP calculation
I know that EVOscan like DSMlink just does a calculation off engine parameters like speed/acceleration, weight of vehicle, drive train ratios, barometer, air temp, coefficient drag, tire diameter. But how accurate is the calculation? Has anyone compared numbers with a dyno session? Just curious because below is a 3rd gear pull after tuning my hi throttle settings with evoscan and my wide band. Just would like to know how accurate it is. It’s still a good means to see if I am making improvements on my tune and bolt on parts. Also was wondering if anyone has the frontal square footage area of the 99 eclipse? Thanks
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09343290 seconds (62.07% PHP - 37.93% MySQL) with 9 queries
