Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 04-03-2006, 03:19 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 4G64T is an unknown
Maf-t and Emanage blue
I have a custom turbo 8g Galant with an emanage setup i was wondering if it is possible to use the Maf translator with the emanage because it says in the directions for the support tool that yyou can not use different style sensors... since mitsubishi's comes with the karman vortex sensors and the GM Maf is a hot-wire setup... Will it work? oh yah im using the greddy pressure sensor with my setup too.
also i know i can use the 2g version of the Maf-t on my car but im wondering what settings to use. is it possible to zero out everything on the Maf-t and just use the GM sensor as a meter then use the emanage to tune with? what do i do about the air temp sensor that is in the stock Maf?
____________________________
» Signature edited due to sig policy violation
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10877109 seconds (51.89% PHP - 48.11% MySQL) with 9 queries
