Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 11-28-2002, 02:12 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: wira4 is an unknown
Wide Band Vs Narrow Band O2
My mate has two o2 sensors on his o2 eliminator,one is a Motec wide band o2 sensor, and the other is a 4 wire NTK narrow band o2 sensor next to the Motec.
As he goes WOTs on his car, Motec WB sensor reads 11.6 air fuel on its display while the NTK narrow band reads 0.69volt on his Jumptronix. He has checked all wirings and nothing appears to be amiss. The NTK appears to be normal at vacuum and low boost but will read between 0.65 to 0.79v at WOTs above 20psi boost. Moreover, the NTK has only about 4000 miles on unleaded fuel and still quite responsive.
From readings off NTK, the NTK is totally off as oherwise he could have blown his motor long before. To verify that, he checked his spark plugs and all appeared rich.
The NTK seems to be crap when working at high boost. What is your view on this?
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.08782291 seconds (65.38% PHP - 34.62% MySQL) with 9 queries
