Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 06-28-2005, 10:58 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: wrx2dsm is an unknown
Difficulty of DSMLink Tuning
How difficult is DSMLink to use? If someone can tune with an AFC, would they experience trouble transitioning to DSMLink? I am not very tuning literate but my friend is very experienced with AFCs and loggers. I personally see the benefit of using DSMLink in place of the logger and the AFC. I already have a both a Palm and 2 laptops. He has the logger software. Should I just stay with an AFC cause thats all I need for basic tuning? Planning on running either the EVO16g or AGP RS49 with 660's and supporting mods. Any advice would be greatly appreciated. Thanks in Advance
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 06-28-2005, 11:24 AM   #2 (permalink)
Proven Member
Jetblack's Avatar
Region: Gulf Coast
Reputation: Jetblack is an unknown
DsmLink is the greatest thing since sliced bread. It is simple to use once you understand all that it can do. It comes with a couple of manuals and a great forum to help out with any issues. I wished I would have gotten first before I began upgrading so it would be easier for me to see how each upgrade affected engine performance because if you don't know how your engine is doing stock its hard to figure out if an upgrade took it way off base or not. But I love it and haven't had any issues with it.
Offline
Old 06-28-2005, 11:50 AM   #3 (permalink)
Proven Member
Reputation: kalla is an unknown
I would point out that DSMLINK is *NOT* an AFC, you are modifying the fuel and timing maps in the ECU instead of "fooling" the ECU to read lower than normal air readings like you do with an AFC. The DSMLINK user's guide is freely downloadable from their webpage, read through it to see more about what it does. It really is an amazing tool, get the link and a wideband and you will be set
Offline
Old 06-28-2005, 06:06 PM   #4 (permalink)
DSM Wiseman
dsm-onster's Avatar
Region: Mid Atlantic
Classifieds Rating: (6)
I must agree
Quote:
I just got dsmlink like 3 days ago. and it is truely phenominal... I don't come from tuning w/ AFC but w/ MAFT but the consept is the same. I had to "detune" my brain from working w/ maft (piggybacks) to working w/ the ecu. In other words, I don't need a translator to suck the ecu into doing something it doesn't know its doing. I can communicate directly w/ the ecu and tell it what i want in terms I understand and the ecu then goes and does it
EDIT: BTW, getting the ecu to do something that it doesn't know it's doing can get you into trouble, i.e. safc: makes ecu run high timing at high boost because you told the ecu that there is less air coming into the engine so that you can lean it out .
____________________________
Matt
dd '90 GST, Holset H1C
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 06-29-2005, 07:00 PM   #5 (permalink)
DSM Wiseman
DGajre777's Avatar
Region: Southeast
Classifieds Rating: (15)
I'm half way through reading the Users guide for DSMLink from their website that I downloaded and printed today. It doesn't seem to be that hard, so far... Lots of good things on it I like though, especially the 'you don't have to lift your foot off the gas to change gear' feature.
Offline
Old 07-07-2005, 10:47 PM   #6 (permalink)
Proven Member
Reputation: truwarrior is more helpful than not
My car was slow with it running 11:1. Then I bumped up the timing in DSMLink and it's A LOT faster. Not much adjustment can be made for that on a SAFC.
Offline
Old 07-11-2005, 03:44 PM   #7 (permalink)
Proven Member
Region: NorCal
Reputation: azkikr10 is an unknown
Download their manual on dsmlink.com and see for yourself. It looks pretty damn simple to use in my book.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.14966989 seconds (76.95% PHP - 23.05% MySQL) with 9 queries
