Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 05-26-2005, 09:36 AM   #1 (permalink)
Proven Member
Classifieds Rating: (6)
Reputation: DSMTalonAWD51 is an unknown
My tuning Experiences
Just thought id share my tuning experiences. I am not reccomending my methods to tuning newbies, but just sharing what worked great for me.
Installed FIC 680's. Used logger to set STFT's for the LO's perfectly, however I just could not get the HI's dialed in with the logger. o2 voltage is useless, it cxhanges with every run, and no matter what settings I tried my timing had dips, and the car would just not "feel" right. What did I do? Said to hell with the logger for now, its just confusing me more than I need to be. I preset my highs at -18% because I KNEW that would be rich. Did a run. Car accelerated slowly, gurgled like a rich car would, and I smelled gas. Leaned it out 1% and did another run. I repeated until my car started feeling faster. Finally I got to the point to where my car accelerated strong and felt/sounded just like it did with the stock injectors. THEN I stuck back on the logger, log looked pretty darn good. Leaned the bottom out 1% more, and left the top just a tad richer, and now my cars running great. Tonight ill start cranking the boost as close to 20psi as I can get.
I feel that I know my car well enough to do this, having a boost leak for a month helped me to know exactly what too rich sounds like, and riding in my friends car let me know exactly what too lean sounds like Anyway, once again not reccomending this to everyone, but it feels prety good to have that confidence in knowing I can. The tuning was done at 11psi and obviously I wouldnt raise the boost any higher until I could confirm that my tuning was accurate with the logger.
Anyway heres the log:
http://pg.photos.yahoo.com/ph/dskate...60.jpg&.src=ph
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10517597 seconds (66.69% PHP - 33.31% MySQL) with 9 queries
