Fuel cut stop the car
Hi when i hit the fuel cut the car stall at high rpm... look like lost the power on the ecu. The rpm fall to 0 but the engine still running because i don't push the cluth. If i try to start the car it don't start. I put the ignition at off after 30 seconds i hear 1 relay make is clic and i could start the car. Someone understand. Thank you
