Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 05-08-2005, 01:57 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: SHDOW90Talon is an unknown
1G-specific Hows my Log
I would like to see what some of you guys think. I believe I can go leaner in the midrange and richer on the topend. None the less Im still on the stock SMIC, so Im figuring thats why I got those counts of knock up top. I felt the car bog down on the topend when I did this run, Could that also be where the car runs out of breath?
It was ~60 degrees when I logged this, and im running 16 PSI
Time,RPM,Knock,Timing,O2,Inj P/W,Air Temp,TPS
0:01.13,3625, 0, 20, 0.88 ,13.333 ,96 ,99
0:01.30,3750, 0, 18, 0.90 ,15.128 ,96 ,99
0:01.47,3812, 0, 18, 0.90 ,15.385 ,98 ,100
0:01.62,3844, 0, 18, 0.90 ,14.872 ,98 ,100
0:01.79,3906, 4, 17, 0.90 ,14.615 ,97 ,100
0:01.94,4031, 4, 17, 0.90 ,14.872 ,96 ,99
0:02.12,4094, 3, 17, 0.90 ,14.872 ,98 ,99
0:02.28,4156, 3, 17, 0.88 ,15.641 ,98 ,100
0:02.45,4250, 3, 18, 0.90 ,15.897 ,98 ,100
0:02.59,4250, 3, 18, 0.88 ,15.641 ,97 ,100
0:02.75,4344, 2, 18, 0.90 ,15.897 ,98 ,100
0:02.92,4438, 2, 17, 0.88 ,16.154 ,98 ,100
0:03.06,4469, 4, 17, 0.90 ,16.667 ,98 ,99
0:03.22,4625, 4, 17, 0.88 ,16.667 ,97 ,100
0:03.35,4625, 3, 18, 0.88 ,16.923 ,98 ,100
0:03.49,4688, 3, 18, 0.90 ,16.667 ,99 ,100
0:03.61,4688, 3, 17, 0.88 ,16.923 ,99 ,100
0:03.74,4781, 3, 17, 0.90 ,16.667 ,99 ,100
0:03.87,4844, 2, 17, 0.90 ,16.667 ,98 ,100
0:04.00,4906, 2, 17, 0.90 ,17.179 ,99 ,100
0:04.13,4906, 2, 17, 0.88 ,17.179 ,99 ,100
0:04.25,5062, 2, 17, 0.90 ,16.923 ,99 ,100
0:04.35,5062, 2, 17, 0.90 ,17.179 ,99 ,99
0:04.46,5094, 1, 18, 0.88 ,16.667 ,99 ,99
0:04.58,5219, 1, 18, 0.88 ,16.923 ,99 ,100
0:04.71,5250, 1, 20, 0.88 ,17.179 ,98 ,100
0:04.82,5250, 1, 20, 0.88 ,17.179 ,98 ,100
0:04.93,5375, 1, 20, 0.88 ,17.179 ,101 ,99
0:05.03,5344, 0, 20, 0.88 ,16.923 ,101 ,100
0:05.13,5406, 0, 21, 0.88 ,17.179 ,101 ,100
0:05.23,5406, 0, 21, 0.88 ,16.923 ,101 ,100
0:05.33,5438, 0, 21, 0.90 ,16.923 ,101 ,100
0:05.43,5406, 0, 21, 0.88 ,17.179 ,99 ,100
0:05.56,5625, 0, 21, 0.88 ,17.179 ,100 ,100
0:05.69,5562, 0, 21, 0.88 ,17.436 ,101 ,99
0:05.79,5719, 0, 21, 0.88 ,17.436 ,99 ,100
0:05.89,5750, 1, 21, 0.88 ,16.923 ,100 ,100
0:05.99,5719, 1, 21, 0.88 ,17.179 ,101 ,99
0:06.10,5781, 1, 21, 0.88 ,17.179 ,101 ,100
0:06.22,5875, 1, 21, 0.86 ,16.923 ,99 ,99
0:06.32,5875, 0, 22, 0.88 ,17.179 ,101 ,100
0:06.42,5812, 0, 23, 0.88 ,16.667 ,100 ,100
0:06.53,6031, 0, 22, 0.88 ,17.436 ,99 ,99
0:06.63,5969, 0, 22, 0.88 ,17.179 ,100 ,99
0:06.74,5906, 0, 22, 0.86 ,16.667 ,101 ,100
0:06.85,5969, 0, 22, 0.88 ,16.410 ,101 ,100
0:06.95,6031, 0, 21, 0.86 ,16.410 ,101 ,99
0:07.06,6188, 0, 21, 0.86 ,16.410 ,101 ,100
0:07.17,6188, 0, 21, 0.88 ,16.410 ,101 ,100
0:07.28,6250, 0, 21, 0.88 ,16.667 ,102 ,100
0:07.39,6250, 0, 21, 0.86 ,16.154 ,100 ,99
0:07.50,6281, 0, 21, 0.86 ,16.667 ,100 ,100
0:07.61,6281, 0, 20, 0.86 ,16.154 ,101 ,100
0:07.72,6344, 0, 20, 0.86 ,13.846 ,101 ,100
0:07.83,6438, 0, 20, 0.86 ,13.077 ,101 ,100
0:07.94,6500, 0, 19, 0.88 ,16.410 ,100 ,100
0:08.05,6469, 0, 20, 0.88 ,15.641 ,100 ,100
0:08.16,6406, 0, 19, 0.84 ,16.154 ,99 ,99
0:08.28,6562, 0, 20, 0.88 ,16.410 ,100 ,99
0:08.39,6531, 1, 18, 0.86 ,15.641 ,100 ,100
0:08.50,6531, 5, 17, 0.86 ,15.641 ,100 ,100
0:08.62,6656, 12, 15 ,0.86 ,16.154 ,101 ,99
0:08.73,6562, 11, 15 ,0.86 ,16.154 ,100 ,100
0:08.85,6719, 11, 15 ,0.86 ,16.154 ,101 ,100
0:08.96,6719, 11, 16 ,0.86 ,16.154 ,100 ,68
0:09.08,6719, 11, 16 ,0.90 ,3.333 ,101 ,11
0:09.24,6281, 6, 43 ,0.84 ,2.051 ,101 ,11
0:09.41,5781, 0, 45 ,0.73 ,1.282 ,102 ,11
0:09.57,5375, 0, 45 ,0.86 ,1.282 ,100 ,11
0:09.73,4875, 0, 45 ,0.80 ,1.282 ,100 ,11
0:09.88,4625, 0, 44 ,0.75 ,1.282 ,100 ,11
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12251091 seconds (71.34% PHP - 28.66% MySQL) with 9 queries
