Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 11-07-2002, 06:51 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 4G63dsmpwr is an unknown
Fuel Cut Defender Question?
I'm going to attempt the 10K resistor mod on my 1G MAF later tonight/tomorrow. I just want to make sure I have everything right about it: Your supposed to install a 10K resistor in line with the intake temp wire (which already has some sort of resistor or something on the wire right, to help me identify it, does anyone know a color offhand?). And after doing this I've heard that it can make tuning easier and also prevents fuel cut, is that correct? Since its gotten colder out I can only run 15lbs of boost w/o hitting fuel cut, how much will I be able to turn it up, if any? Thanks a lot, Erick
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09848690 seconds (60.00% PHP - 40.00% MySQL) with 9 queries
