Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 03-13-2005, 10:13 PM   #1 (permalink)
Proven Member
Classifieds Rating: (1)
Reputation: Twizzle is an unknown
maft tuning/ logs included
i just started getting around to using my maft with 3"gm maf. when i go wot it pulls nice from like 2500-4.5 but from 4.5 up it just doesnt pull any harder. my timing is all sorts of screwed up and im bombarded with too many things to handle right now. can someone tell me wtf is up with my logs...btw these were two short little pulls because i was afraid of blowing up my car, however egt never went over 1350f so im guessing im running a tad rich? i need someone to point me in the right direction. can i start using afc or should i fidaddle with maft more
these logs also might be messed up so i have no clue cause after about an hour of trying to absorb the technique and testing and fiddling i just got fed up with it.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 03-14-2005, 08:40 AM   #2 (permalink)
Proven Member
Timeslip: 14.670 @ 97.200
Classifieds Rating: (0)
Reputation: 12sec92Tsi is an unknown
Is it just me or does your O2 voltage seem a little lean?
____________________________
-Steve-
Offline
Old 03-14-2005, 08:54 AM   #3 (permalink)
Proven Member
Region: Tri State
Reputation: gsxeclipse102 is an unknown
i would try to get the low fuel trim at 100 and not 81 % first. The timing looks fine in those logs. They are at 20 degrees which is normal.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10299993 seconds (68.84% PHP - 31.16% MySQL) with 9 queries
