Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 12-08-2004, 05:24 PM   #1 (permalink)
Proven Member
Cirus_93TSI's Avatar
Region: Mid Atlantic
Classifieds Rating: (0)
Reputation: Cirus_93TSI is an unknown
tuning: race fuel vs pump
i only found a handful of thread about race fuel tuning, and every one basicaly asked and said the same thing. "how should i adjust my tuning when adding 116 octane fuel?", "you should upp the boost and maybe lean out a little if you didnt raise the boost alot"
what i want to know is the exact opposite. if a car is tuned on c16 throughout the rpm range, and never runs on anything but c16, what would be the most effective way to detune for lower boost on pump gas(93)?
i want to lower the boost from 28 to about 20 and tune for pump gas. 20g internal gate, 660's, afc, 2g mas, pocketlogger.
should the low settings stay the same? would the lower octane even make a difference at idle and low rpm cruising? for the high settings i assume i richen up the high map untill the logger readings are within range, but will the curve be different? or will it be the same curve(in general, not exactly) with more fuel all across? or will some of the rpm range need more adjusting then other parts?
would all the TH points and everything on the afc be the same? and how about mid rpm cruising(like low boost situations, acceling on the highway and such)? would the settings be the same or would i need to compensate there too?
thanks in advance for any help.
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09894896 seconds (61.45% PHP - 38.55% MySQL) with 9 queries
