Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 12-06-2004, 08:18 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: COHIBAGSX is an unknown
1G-specific Msd Dis-2 Tunning Switch Settings
I am installing the MSD Dis-2 ignition with the 2 tach adapters. On the side of the MSD Dis-2 box there are switches that need to be set. I set the staging rev @ 4500rpm for 1G GSX and 7250RPM max speed rev limit.
What settings should I set my:
- Max/Min Rev (+)
- High Speed Retard
- Electric Start
- Waste Spark
- Max Timing
- Max Speed Retard
- Timing Set Up
- Retard Begin Speed
If possible please explain why?
I have the following mods that maybe a factor for ignition tunning:
MSD 8.5mm Spark Plug Wires, NGK BP7ES plugs, HKS 272/264 cams, AEM Cam Sprokets with intake retarded 2 degrees/ Exhaust set @ 0 degrees, Unorthodox Crank Pulley, Removed the Balance Shaft & Belt, No A/C or Power Steering, Ported Head, EGR Blocked off, etc..
Thanks!
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.10034108 seconds (59.33% PHP - 40.67% MySQL) with 9 queries
