datalogging problems
Novtec1
71
Jun 2, 2002
wanted to start logging today, got onthe autobaun went othe datalogging screen, pressed go and started...came back with" cannot connect with ecu" for some reason i thought i hooked it up wrong so i pulled over, checked all the wiring and everything was good went ot start again and came up with the same problem. been trying since 2:45 this afternoon to find out what the problem is (its 9:34 pm now) and i can't seem to find out whats wrong. if anyone knows what the problem is please point me in the right direction this is really pissing me off. thanks.....:D
Check the cable connecting to the diagnostic port. Also, is the power wire connected properly? It go to the fuse box and it often came lose after some driving.
