Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Tuning & Engine Management
Tuning & Engine Management EPROMS, ECU, MAF, knock, EGT, wideband, datalogging, fuel trims, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack Thread Tools
Old 05-28-2004, 07:48 AM   #1 (permalink)
DSMtuners Supporting Vendor
GVAutosport.com
Region: Tri State
Classifieds Rating: (1)
Reputation: spendone is more helpful than not
Noob at tuning, need help.
I currently am running a MAFT blow thru setup. Im logging my car with TMO logger. As for my mods they are in my profile. The problem is that I am having the worst luck trying to tune this thing. Ill tune it and the following day it will run like sh!t. The same thing always happens though. It always tends to lag and get random misfire around 3000-4000 if Im building up any boost. Im pretty much tuning for knock. I just need to know what values I should be looking for when tuning. And also what are the max values of those settings. Currently I am tuning with my high, mid, low fuel trims and knock sum. Please help guys, im getting really frustrated with this.
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09379005 seconds (61.65% PHP - 38.35% MySQL) with 9 queries
