dsmnate
- 415
- 1
- May 9, 2002
Hershey,
Pennsylvania
Ok, so I bought the extreme camber kit for Extreme Motorsports and tried to install it last night. I started at 9:30 and after some swear words and a couple of hours of breaking bolts loose got the kit installed. Here is where the problem begins.......
When installed I set the camber kit to what I thought would be the medium adjustment of about +2.0 degrees. The kit goes from +1.75 to +3.25. When I tried to lower the car the upper control arm hit the fender well....hmmmm.....they said it bolts right up and is easier to install than others......Ok so I thought well I only really need to be between -.80 and +.20 so if I set the kit to the lowest amount of change then it should clear and everything will be ok....Well after removing the tires again and all of the pain in the a$$ bolts I set the camber kit to the fartherest back setting that should have been closest to +1.75. Put the tires back on and let the car down and it still didn't clear. Well now it is like 3:30 in the morning and I have to be at work by 8:00 so I said screw it I am going to put the stock setup back on and I got it back together by around 4:00......
My questions are:
Has anyone else installed a camber kit?
Do I have to cut the front fender wells for a camber kit to work?
If I put all the stock setup back the way it was will my toe in/out be really messed up and kill my tires if I don't fix it right away?
Thanks in advance,
-Nate
My questions are:
Thanks in advance,
-Nate
!!! What keeps taking the most time is that the rachet keeps getting caught in the coilspring and being a pain in the A$$ and then the bolts get stuck and won't come out and the blah blah blah.....
