Onnipotente
- 105
- 0
- Oct 16, 2003
Can removing the air filter give you increased air flow?
it wont run wtf u ppl crazy???If u just remove filter but keep ur MAF attached u ll have no problem it will run as it was with filter and yea ai ll get better flow but i dont think it will make any diference cuz if u use good filter the flow is pretty much same.Not measurably, no. Unless you're currently using a clogged filter.Originally posted by Onnipotente
Originally posted by bclipse96
If you would have read our post you would notice that we said that our tube popped off not just the filter.
Originally posted by TBSpyder
So then your previous post did not even pertain to the original post...being his question was specifically about JUST the filter and not the entire tube. Thanks for wasting everyone's time....![]()
I wouldn't even consider it..............Ever. Even for a five-minute drive around the block.
Like posted above the risks endless and if you love your DSM use a filter!
VelocitàPaola said:there was no air filter whatsoever - just a straight pipe running to the intake manifold. If you were there when I started it, you would know immediately exactly why not to do this.
The engine shook so much, I would've been afraid of suspension failures. Anything and everything that was in the engine bay got sucked into that poor motor. I can't even imagine what the internals must have looked like.
That poor car WTF
