My evo 3 9.71@148 vid
Very nice. It's always nice to see what people outside the US are doing with their rides and what achievements have been accomplished.
Big kudos from me to you! :thumb:
Nice run. Any info about the car's build?
Its quite a simple set up
Im running a Haltech E11V2 ecu, MSD Dis ignition, twin plate clutch,4 speed dog box, A garrett GT35R turbo with a 66mm front wheel and a 1.06 exhaust housing, HKS Wastegate,
the usual cylinder head(1mm larger valves dual springs ect and crower cams over 300 duration, porting ect), standard crank, eagle rods and cp pistons.
Cometic head gasket, arp head studs, flywheel bolts and mains.
The engine is 3 years old now and I have done around 150 passes with about 20 of them in the 9's:)
Im using C16 for the track and Shell 100(pump) for the street and no n20.
on c16 and 32 psi on a dyno dynamics dyno it makes 670 at 4 wheels ans on pump(100) it makes just over 500 (24 psi) and revs out to 9600
I have run a best of 9.67 and a best terminal 150.9 on BFG Drag Radials 235/60/15's
the car with me in it weighs 2950lbs.
Im racing this weekend and after this meet, im taking the engine out and possibly doing a 2.2 for the next meet in august.
Cheers:D
