Blitzeclips
- 1,571
- 6
- Aug 5, 2004
Bear,
Delaware
Alright guys I finally finsihed most of my turbo kit. I will be doing a brief write-up on the process when I have time, but for now heres some pictures from the install. I still need a downpipe. I will be having the car towed to a shop for a custom one to be made. Hopefully 3".
List of items/mods for conversion:
Custom Log style exhaust manifold
MHI Super 20G turbo w/ internal wastegate
FMIC
Homemade manual Boost controller (Soon to be Dual stage MBC)
Vortech 12:1 FMU
Autometer oil pressure and boost gauges
Aeroqip hoses and SS lines
Walboro 255lph fuel pump
Custom I/C plumbing (used Hahn SMIC kit w/ modifications)
3" Tsudo Cat-back
3" test pipe
2.5-->3" downpipe w/ flex section (will be modified for fitment at shop)
For the most part this is everything I have, or can remember.. Along with my built and stroked motor..
For the time being I will be running 8psi on stock injectors. When I upgrade injectors I will be using a DS MBC and SAFC-II with dyno tuning using wideband by Slow Boy Racing.
We started the car and everything sounded fine, it was just a little loud with no downpipe
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics001.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics002.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics003.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics005.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics007.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics010.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics012.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics013.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics014.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics019.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics017.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics018.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics023.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics025.jpg
This below is the sending unit assembly teed into the block..
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics026.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics027.jpg
Had to get a thinner fan for the turbo clearance..
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics029.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics033.jpg
Needed to make a bracket for the wastegate.. The housing was swapped so the actuator was LOW.. looks ghetto now but we shaved it up some..
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics037.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics041.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics044.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics046.jpg
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics048.jpg
We noticed a pinhole leak on the oil pan when we filled her up.. THIS is what happens when you start the car...
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics056.jpg
It supercharged..
http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics057.jpg
Sorry for all the pics but like I said I took alot to document this later. Probably a write up..
FMIC
Vortech 12:1 FMU
3" Tsudo Cat-back
3" test pipe
. http://i35.photobucket.com/albums/d162/blitzeclips/turbo install/turboinstallpics001.jpg
It supercharged..
Cmon now. 76 views and 1 reply? Give me some inputs here guys I've worked hard and long on this. Most of you helped me to get this done believe it or not... eh, oh well then...
