MitsuBoost
Banned Member
- 59
- 1
- Sep 23, 2003
818 - 909,
CaliforniaUS
i have a few questions before i begin buying the parts, i plan on getting the nozzle from mcmaster.com and i determined how much water/fuel ratio i need in CCs, but the sizes are in GPH (gallons per hour), anyone know the conversion from CCs to GPH? Also, is a 60 psi pump enough pressure for good atomization? And lastly, is a solenoid really necessary, shouldnt a check valve be good enough?
edit - Also what water/fuel ratios are you guys using? coolingmist.com says 10-15% while rbracing-rsr.com says 12-25%, i could play it safe and call it 15% but i want to get an idea from 1st hand users
