Can Anyone Top My Fire in the Engine Compartment Story
98GSX-WI
131
Jun 6, 2004
Kenosha, Wisconsin
I've said before, if you own a modded DSM long enough...eventually you will probably see many of the problems that you read about here in the forums--but I never expected my car to start on fire.
Last Saturday it was the first time by brother got to ride in my car. He has a 440hp cobra. I really didn't have a good place to show him what my car could do. I only got into boost once, came to a stoplight...and then the car died. It would not restart. So after having my brother push my car to the side of the road and scratching my head for a while, I finally figured out that the ignition fuse had blown.
I switched the 30amp fuse from my power windows, restarted the car and made it to a auto supply store where I bought their last 3 fuses. Luckily there was a Mitsu dealer a block away. I blew two of the three new fuses just getting one block to the dealer. The last time the fuse blew is when I turned off the turbo timer (exactly when I hit the switch)--so I thought that the turbo timer was shorting something out because it is wired into the ignition.
Left the car with the dealer and they disconnected the turbo timer and drove the car around a while and then let it idle a long time...and the fuse didn't blow anymore. I paid $90 in labor and picked it up on Monday and drove it 25 miles home.
I then drove it to work (35 miles) and when I got into the work parking lot, sure enough, the fuse blew again. I made arrangements to take it to a close-by shop to check the wiring for shorts--had someone take me to buy more fuses at lunch for the short ride to the shop just in case the fuse blew again. (Not really a smart idea to test my luck any more).
Now is where the fun started. Put a new fuse in, started the car and it blew right away. Put another new fuse in and just turned on the power so that I could shut off the other electrical stuff in the car. Went to shut the hood so that I could start the car again and take off....and there it is, a fire near the bulkhead (would say firewall, but too much of a pun). The fire was about 6 inches wide and 4 inches high. Lucky I have a fire extinguisher in the car, so I was able to put it out right away. (My advise...I suggest everyone keep a fire extinguisher in their car).
I was kind-of puzzled as to what electrical wiring could have started a fire in that location, but had my car towed to the shop. I should note that the great thing was, I extinguished the fire very soon, so there was no visible damage to anything. As soon as I got to the shop and we started to look around the area, we found the problem.
The braided fuel line had pinched a wire up against the intake manifold and wore it bare. The continued arching of the wire had penetrated the fuel line until a hole had formed and it started to leak. It was actually gasoline that was burning! I can't imagine if I would have started the car again with the fire there and if fuel would have sprayed into the engine compartment.
That is about it for the story...I believe that I made a dumb mistake by continuing to replace the fuse to try to get the car to the shop and not towing it right away. But then again, I was also smart for having the fire extinguisher handy...LOL. The fire actually turned out to be a good troubleshooting technique (ha, ha), because I think that it would have been very difficult to have located the short--because I think that most people would have looked at the battery, fuse box, or the ignition wiring under the steering column.
I put this story in the bolt-on section...because it did involve the fuel system...LOL. Hopefully, you guys will learn from this story and maybe avoid the same thing from happening to you. Later.
The battery arching is probably a big cause of fires. The shop that I took my car to said that a customer of theirs left their shop like a bat-out-of-hell and the battery shifted, fell on its side, and started the car on fire a few blocks away. The engine was OK, but all of the wiring was melted.
It seems like most underhood electrical fires are from things that people have added to the car on their own. :dsm:
The only way I can top your story is with my rear diff fire that I did'nt know about for miles on the interstate. I happened to look in the mirror and saw what I thought was "a ton of fog tonight" when I pulled over and had my buddy walk out back to check it out, LOL he opened the door and looked back at it and looked over at me and said "OMG the f'n back of the car is blazing". The only thing I could say was "it still has good oil pressure though, look. (as I revved it up)" For some reason I figured that if it actually WAS smoking that it had to be oil leaking all over the place and that I would notice it on the oil pressure gauge. The next thing we did is walk out back and try to flag someone down to give us some water or something to put it out with, but no one would stop. After about 5 minutes I said "hey wanna just keep driving it, because the further we get to home the less we will have to walk" LOL. we had nothing and I mean nothing to put it out with, and we were on our way back from sumitt racing on the interstate, (it was freezing out and we had short sleeve shirts). We ended up literally pi$$ing on the thing to put it out. ROFL . Then the next day when we trailered it home we ended up loosing the brakes on the truck we were towing it with while we were heading down a nice steep hill at around 55 mph WTF . Fun, fun, fun. I bought an extinguisher the next day. :nono: :dsm:
That was the first thing that came to my mind when you said no one would stop and nothing to put it out with. A plus over the ladies..We hae built in fire extinguishers. ROFL ROFL ROFL ROFL ROFL ROFL
who has that vid of the fully built 1g burning to the ground on its first launch. Launched, stuttered and went up in flames. Driver walked away holding his head. That thing was soooo sexy :(
I had a custom made fuel rail for my 420a setup, and lets just say the brackets on it were pretty thin. Anways When the fuel presssure went up after hitting boost a several times during the day, the fuel rail pushes on the brackets and bent them back a little,causing the injectors to come out just a little bit. Had fuel everywhere under my hood, (luckily I shut her off as I was making it back to my dorm, and coasted there.) RE Welded the brackets and haven't had a problem.
Fire's suck, lets just say I think all modded eclipes need to have a fire extinguisher in it. I'm ordering mine now as we speak.
mitsuclipsegsx said:
did u have full insurance
Yep.. paid it off..
I didnt see a dime from the 6k in mods I had done to it.. That kind of thing makes baby jesus cry.. heh
But im back to a 99 eclipse... again..
See that what I'm so afraid of, something happen to my car and not see anything for the stuff I put in it. I keep all receipts and a folder for anything I buy online, just in case.
A fire extenguisher on a modded car is a really good idea. You always say "it will never get used", but the day it does you are very glad to have had it.
Mike
My Near catastrophe.
Cliffs Notes version:
My amp subs and speaker box were all stolen from my trunk.
I was pissed.
Only the power, remote, and other wires were left in my trunk.
I don't have anything in my trunk but the bottom of the car aka metal.
I decided to move away from the apt complex that my car got raped in.
My girlfriend packed up my trunk with stuff from my crib.
Half way to my new crib the weight of the stuff in my trunk causes the power line that used to go to my amp to ground.
The in-line fuse doesn't blow because, well, I didn't have one.
Lights on my dashboard go dim, engine power diminishes, I see and smell smoke!
I swoop onto the next street and park.
I pop the hood. The power line has turned a bright red all the way from the battery to my trunk like some kind of sick heater element.
My girl freaks out and I send her to some peoples house for water. Meanwhile...
I see flames grow about a foot high and realize that if I don't act soon I will surely lose my car. I reached down and with my bare hands I broke that red hot wire off at the battery.
Disaster averted. After 6 or 7 hours my heartbeat returned to normal.
My hand had a black line in it that washed off with soap and warm water. :)
My battery is held down with the O.E. holder.
I got rid of the damn strut bar.
All of the aftermarket wires are fused: 100 amp breaker at the battery and fuses at each component.
Fuel system is all AN.
A/B/C extinguisher is mounted near the front of the passenger seat.
I've seen way too many DSM fires and don't need to add to the list.
My sister was dating a guy with a P.O.S. Merkur xr4ti. There was a known leak in his injector o rings and my sister was bitching at him to fix it but the guy just kept driving the car. They stopped by the house and lil' sis pulled me aside; "Talk to him will you? He respects what you say about cars and might listen." At this point, I walked out to my shed and returned with an A/B/C extinguisher and handed it to him. "What's this for?" he asked. I told him if you gonna' drive a ####ed up car with leaking injectors, you'll likely need this before I will." The very next day, the car burst into flames. The extinguisher did the job, he restarted the car and drove off.....
