Stapl3
- 1,827
- 397
- Oct 27, 2004
MI,
Michigan
A 20g.AK1RA07 said:what would you guys reccomend for if my end goal is in the 400hp range?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Stapl3 said:SBR manifolds are useless, just port your 2g one.
Wastegate on the o2 housing would be cheaper and better performance wise.blcknspo0ln said:but if I go external, the SBR cast manifold with wastegate option will be my first investment
steel_3d said:Why is the sbr/evo3 manifold useless? Can you guys port the 2g's to match the bullseye?
I guess I'm in a shitty spot cause my compressor doesn't cut the mustard...
ceedawg said:Anyone have dyno's or time slips with the holset turbos? Is there also a link for these dyno's as well?I certainly cant find it anymore.
Wow your hx40 is doing lot with the stock 6 bolt. Which hx40 do you have the 58mm or 60mm? What kind of gains do you think you will see off of cams and smim?Steve93Talon said:Just an update, we just got home from the track with the HX40. Went 11.53 @ 125.4 right off the trailer. Shift problems kept it from making another clean pass. This is on a stock 6 bolt, stock head, stock cams, stock intake, stock susp, fulll weight, all season Kuhmos, spinning through 1st and into 2nd, and short shifting the 2-3 shift at like 6k. The car is running 27-28psi, still learning as we go on the AEM. I can seriously see 10s on a full weight, stock intake/cams 1G with this thing! Anyone who's doubting it's abilities doesn't have a clue what they're missing. It's the most quick spooling, streetable big turbo I've ever driven on a DSM.
spoolinawd91 said:Wow your hx40 is doing lot with the stock 6 bolt. Which hx40 do you have the 58mm or 60mm? What kind of gains do you think you will see off of cams and smim?
boostmaniac said:The army uses this on a track vehicle, Fricken HUGE!
